Question about Abit RX600PRO-GURU RADEON X600 PRO GURU, (256 MB) Graphic Card
System Fan Speed shows 0 and the computer is crashing is thats why its doing it? tempiture 46 / cpu speed 2960-3016rpm
    Problem Solver:
  • 15 Answers
If the fan is not running at all, then yes, it may be overheating. If the side of the computer is off, can you see the fan spinning? If not, yes. You need to replace the card.
Try this program. It will show you the temps and speeds as well as give an alarm if it gets too hot. http://www.almico.com/speedfan.php
Posted on Jul 19, 2009
Laptop cooling fan running at very high speed
Try loading and using a program called speedfan to control your fan speed if that is appropriate. This can also show you your CPU temperature (if you can figure it out). Core Temp can show you temperature of modern CPUs, amongst others.
Otherwise try cleaning you CPU of dust - search the internet as to how to this safely.
18.April.2014
Feb 05, 2014 | MSI pr600 fan
Laptop crashed
Really need more information, but my guess is dirty fan. If fan is blocked by dust, it may make noise and may run at high speed all the time because the CPU is overheating. If CPU gets hot enough, the laptop will shut itself down without warning. If dust is the problem, get some canned air. Before blowing into the air vents, try to spot where the CPU fan is and gently insert a toothpick to block the fan and prevent it from turning. A long blast of compressed air can spin the fan too fast and burn out its delicate bearings. Blow air from underneath and also from the side vent until air blows clear. In some bad cases of dust, the bottom or top cover must be removed to get it all out.
Sep 25, 2013 | Dell Vostro Computers & Internet
My CPU Heat
You should check Task MGR and see what process's are running, you need to find out if the CPU is being pushed, when you are not doing anything the CPU should be close to zero or between 0-10 percent.
So if you check and find the CPU is running at Idle, then you check the CPU fan clean it.
You should install software that will show you the CPU temp and fan speed, as you work the CPU through software running, the fan should increase in speed.
If the CPU is not staying cool near 40C, then look for a better cooler.
Thermal compound has no miracle, the cooler is what is important, and the case fan is not as important as the CPU cooler itself.
Dec 02, 2012 | Computers & Internet
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
So I have ASUS silent sqare pro CPU cooler for about 6 months, but the little blue thingy that shows the fan speed died, well it still shows the speed of the fan but the nice blue light is dead, it just...
Either the blue LED is faulty or the LED needs replacing or resoldering to make proper electrical connection.
If you cannot fix it yourself and the fan functions normally then don't worry about it.
Jul 07, 2011 | ASUS Silent Square Pro - Processor cooler...
My bios shows system fan speed as 0. It seems all fans are working, but i keep getting temp alarms. any ideas? I can see a fan at the front, one at the back, one CPU fan, one graphics card fan & two...
See (in the CMOS SETUP ) if the processor temperature is between 30 and about 50 degrees celcius. If it is way above that then the thermal paste between the fan and the processo has hardened and the contactbetween the processor and the fan is POOR . Replace the paste withy NEW paste. (a thin layer) That usually sorts out that problem.
Aug 03, 2009 | Computers & Internet
Who to overclocke my motherboard'z FSB or my processor?
Hello.
It is not save for your system making it work faster by overclocking it.
Some times it works fine just using the right cooling methods, but some times its leads to system freezes, crashes and even to permanent processor damage.
So i advice you to keep that in mind.
If you want to proceed anyway.
- In newest computers you will find an option to set the processor speed to automatic( system recognize the cpu speed) or manually, in the last one you hve to set the RATIO( Processor speed divided by FSB speed), this means:
- The FSB of your P3 Motherbord (133 Mhz) x 7.5(ratio)= 1Ghz
- In older motherboards the speed option is set using jumpers
configuration in the Board, inthat case you will have to use the motherboard manual( some boards have printed tables) to show you the config.
Note: if your motherboard doesn't show you the RATIO you need is because it doesn't support that speed.
Good look.
Jul 04, 2008 | VIA C3, 800 MHz (VIAC3800) OEM / Unboxed...
Processor slowing down?
On the system properties you will able to check your processor speed and your memory, it is possible that the other description is referring to your memory or Ram.
You can use other program like aida32 to check your computer spec or you can try the steps below.
To check the CPU speed, from the Start menu, select Run... , then enter msinfo32 .
You can also type DXDIAG then enter.
http://support.microsoft.com/kb/312104
Mar 07, 2008 | Computers & Internet
Overclocking
First off... be warned overclocking is not for the faint of heart... now let us begin...
MAKE SURE YOU HAVE ADEQUATE COOLING!!!!
I can't stress this out enough if you plan on overcloking it's worth spending some money on some fan's specifically a CPU fan to make sure it stays cool. A side effect of overclocking is increased heat.
Restart the computer and go into your BIOS. Look for the setting to change the bus speed. Depending on your specific CPU it should be 200 MHz (if it's not don't worry, most computers now are 200 MHz). There should also be an option called the multiplier. This one is usually unavailable. If it is available you have a high-end CPU model that is "unlocked".
THEORY:
The system bus is multiplied by the multiplier and gives you the resulting speed.
200 x 16 = 3200 => 3.2 GHz
IF your multiplier is unlocked you can increase it... it's not then we have to use the system bus.
When you change the system bus it increases the speed of everything in your system... that is the link in between  individual components. But it's a double edge sword... it will cause you system to become unstable more quickly and reduce the maximum overclocking potential.
PRACTICE:
Increase the bus speed 3~5 MHz at a time. Restart the computer boot into the Operating System and run applications you normally would. If nothing crashes, hangs, freezes, locks up... you can reboot the computer and increase the bus speed again. Repeat theses steps until:
a) reach a point where the system becomes unstable
b) you feel like pushing your system more is getting to risky
This is a very basic answer on how to overclock. For more information, guides and other goodies http://www.extremeoverclocking.com/ is a good website for more information and guides.
WARNING: If you push the system to far to fast without doing it gradually you can surpass the computer components limits and cause damage to the computer parts. I am not responsible for any damage that occurs. This is just a guide.
Oct 28, 2007 | Intel Socket 478 CPU COLLING FAN & HEAT...
Abit RX600PRO-GURU RADEON X600 PRO GURU, (256 MB) Graphic Card Logo
664 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
