Question about Zenith Z50PX2D 50 in. Plasma HDTV
I HAVE A PS3 WITH A HDMI . I CAN HEAR SOUND BUT NO PICTURE . HOW CAN I FIX IT
Shut system down completely and turn off power in back then unplug box it up j/k plug it back up turn it back on it may fix itself then mine did
Posted on Dec 24, 2009
  • 3 Answers
You have to plug in your rca cables and go to the display menu, make sure your hdmi cable is also hooked up. change your setting from rca to hdmi and then change eyour tv mode over to hdmi you have to do it quick because the system will change back to normal after 30 seconds
Posted on Jul 19, 2009
5 Suggested Answers
  • 58 Answers
SOURCE: invalid format
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Posted on Sep 25, 2009
Testimonial: "thankyou, that actually worked, i did not know this could be fixed this way"
SOURCE: no sound through ps3 hdmi
on ps3 go to settings sound and change sound out put to hdmi you will see 3 different options
Posted on Nov 07, 2008
SOURCE: ps3 gets sound but no picture when using hdmi cord
hi theres is 2things you can do leave the scart in then go to settings and select hdmi or plug the hdmi lead in on its own switch the ps3 off leave it for 10 seconds and then switch it back on it should then ask you to select hdmi and go through some settings hope this works friend had the same problem
Posted on Jan 10, 2009
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
I was switching my ps3 from hdmi output to the red,yellow and white cords and after i accepted i switched my tv to av1 and there was picture and sound but it then asked me what format and i selected 1080p...
Easy to fix so don't worry ;)
While the PS3 is off (solid red led)
Hold down the power button until you hear the SECOND BEEP, quickly release.
This will reset the video settings back to default.
Feb 01, 2011 | Sony Playstation 3 (PS3) Console
Cant get picture on psa3 slim hdmi or av
conect your ps3 with hdmi to TV then put your TV on hdmi by its remote controler, ps3 is still turned of. Then press switch of/on ps3 buton and hold it for 5 - 7 second cca., You will hear a double beep sound and after that you can turn your ps3 on. Then just follove the instructions.
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound with hdmi
You Need To Setup HDMI On UR PS3.
Happened 2 Me Once.
To Fix:-
Plug Into AV Multi.
Go To Settings
Go To Display Settings
Go To Video Output Settings
Select HDMI And Follow The Instructions
Apr 04, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
Oct 19, 2008 | Televison & Video
I was switching my PS3 from using the hdmi cord to using the regular cord so i could use it on another tv. when i switched the cord settings it had to switch the tv settings on the PS3 from 1080p to like...
so u must go n plug the hdmi cable in a tv dat support an hdmi feature so u can be able to fix the problem from the menu.....if it's not lkike that i think u can use the AV cable on a normal TV ....so u can fix it as well
Aug 19, 2008 | Video Game Consoles & Games
Ps3 video
Try turning off the system then hold the power bottom until you hear 2 beeps. First beep will be power on. Second beep will be reseting display image.
Aug 16, 2007 | Sony Playstation 3 (PS3) Console
Zenith Z50PX2D 50 in. Plasma HDTV Logo
490 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
