Question about Frigidaire FEF336BC Electric Kitchen Range
Bosch gas oven, the gas broiler works but the bake will not work
  • 375 Answers
Find the bake ignitor (you may need to remove the bottom drawer or oven cavity floor) Turn bake on. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
5 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
Maytag317
  • 1136 Answers
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
heatman101
  • 43501 Answers
SOURCE: maytag oven wont bake. stove and broiler work and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 21, 2010
heatman101
  • 43501 Answers
SOURCE: top oven not heating up on BAKE, broiler gas and
heatman101
Posted on Jan 09, 2011
I have a bosch gas range and found the bake igniter to be faulty. Power to it is switched on and off properly. The broiler also does not work but I havent been able to look at that yet. Are both igniters...
The broiler and oven burner are the same. The igniter can be easily(relative) replaced. Remember the igniter is ON the entire time the flame is present, so it will fail with time.
Jan 28, 2014 | Bosch HGS442UC Gas Kitchen Range
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Broiler works Bake Oven doesn
The first thing to check is the oven igniter, check for spilled foods on igniter and clean if necessary
Dec 12, 2009 | Televison & Video
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Frigidaire FEF336BC Electric Kitchen Range Logo
274 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
