Question about Metra Chevy Truck 88 94
There is a leak by my starter
I have a leak and the fluid is leaking on my starter but i can not find where the leak s coming from and the leak is leaking on my muffler pipe causing it to smoke
Rear main seal may possibly be failing
Posted on Jan 04, 2012
  • 107 Answers
Head gasket..... soapy water and a spray bottle on a running motor mite reveal this
Posted on Jul 21, 2009
Oil leak seem to come from starter. What can it be - main bearing oil seal?
Oil leaking around a starter is usually one of three possible things.
If it is motor oil, then suspect the rear main seal.
It it is auto trans fluid, it could be from the transmission front seal or the torque converter
If you have a manual transmission, it could be clutch fluid leaking from the slave cylinder, or a leaky front seal from the transmission.
Mar 06, 2015 | Cars & Trucks
My 2003 hd ultra classic is leaking trans. fluid at the top of the trans. what do i do?
first spray it all clean with brake parts cleaner, careful not to spray on starter. then start it up go around the block and verify where the leak is, if its the top cover get a gasket replace easy fix five bolts. now if your leak is coming from the nipple or short hose thats on the left side of top cover thats a vent and this indicates the tranny is over filled with fluid.
May 12, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
Starter won't engage
I would guess the steering fluid has gummed up your solenoid, making it difficult for your starter to engage the solenoid.
Mar 15, 2014 | 1991 Toyota Pickup
Oil & fluid leaking on starting.
Dear leaking fluid on starter, I suggest that you inspect your engine fluid resevoirs and assess from the lowest one to see if its fluid matches the fluid that has leaked onto the ground. i suggest parking on a large piece of paper or plastic to collect your sample of leak fluid. that is where i would begin. in my opinion, sounds like a leaky valve cover gasket or coolant system leak, ie, waterpump, heater hose. rad hose.....
Dec 12, 2012 | 1996 Buick Century
My 2004 ford ranger automatic transmission fluid leaking from the starters weap hole
Remove the transmission & see if the front pump seal is worn,
where the torque converter goes in
Oct 27, 2012 | 1992 Ford Ranger
Mysterious coolant leak
Check out this few help links,in related to this types of problem.Click the link below :----Transmission fluid gets into radiator?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
The plastic housing which goes to the upper radiator hose is cracked and leaking?
http://schematicsdiagram.blogspot.com/2011/12/plastic-housing-which-goes-to-upper.html
Radiator leaking? http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
--------Car water leak around the Starter area and Bell Housing? http://schematicsdiagram.blogspot.com/2011/12/car-water-leak-around-starter-area-and.html
--------Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
---------This will help.Thanks.
Jan 16, 2012 | 2001 Dodge Neon
I Have a 2001 mits galant and is appears that the trans fluid is leaking from the starter... I have never seen this before, why could/would this happen?
It is probably leaking from the torque converter in the bell housing. The torque converter has seals on it , it is full of automatic transmission fluid, is spun by the motor and in turn transfers the motor energy to the transmission. Have you checked your dipstick for your transmission fluid lately? If it is coming out by the starter there is probably a lot in the bell housing.
Sep 17, 2010 | 2001 Mitsubishi Galant
1999 cougar v6 trans fluid leak after starter replacment
starter replacement itself would not effect transmission,check that transmission cooler lines to radiator were not loosend or damaged changing starter.place a piece of cardboard under vehicle to help pinpoint leak.
Oct 14, 2009 | 1999 Mercury Cougar
Transmission fluid leakage from stater motor area. 5.7L Vortec
If transmission fluid is dripping off the bellhousing your torque converter seal is leaking or your transmission pump seal is leaking. Chances are the torque converter seal is leaking since the torque converter is spinning on it any time the engine is turning, the pump seal dosen't move it just keeps fluid inside the transmission. Even though it leaks with or without the engine running I'm willing to bet if you got underneath it with the engine running you will see it leaks more with the engine running. Now if either seal is leaking it will require the engine to be removed from the transmission to get to the seal. Sorry but this isn't going to be a cheap quick fix.
Apr 01, 2009 | 2001 Chevrolet Express
Metra Chevy Truck 88 94  Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
