Laptop goes black randomly
I've already removed the battery bar from the back of my laptop (Gateway M-285-E) and use just the AC to power it (thanks to a guy who gave me that fix when I couldn't get the thing to work at all), then it began to just shut down - go black, seemingly randomly, until I figured out that I have a bad power cord and it has to be just so for the power to get through. Sigh - what next?!? I really don't need help, but thought this info may be of some help to anyone else experiencing these same problems.
  • 201 Answers
First is the power cord, next is the pin in the dc jack , if it moves just a tiny bit , jack needs to be replaced
Posted on Jul 19, 2009
I have a Gateway NV7802u laptop computer. I was using it I needed to move to another room so I put it to sleep unplugged the AC adapter, by the way I am using the AC adapter because the battery has like a...
Have you tried holding the power button down until it shuts down completely, then unplug the AC adapter, remove the battery, put it all back together then try powering back up?
Mar 27, 2013 | Gateway NV7802U Notebook
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Gateway 600yg2
I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160
In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.html
Here is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdf
Page 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
Aug 20, 2012 | Gateway Computers & Internet
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
My gateway laptop will not hold a charge unless the power cord is jiggled and placed in ackward positions. i assumed it was the ac adapter, replaced it, and now im still having the same problem. does my...
it looks like the battery is already defective. try to remove the battery and use only the ac adapter. if your computer works fine using only the ac adapter, then the battery is already degraded and needs to be replaced.
Jun 11, 2010 | Gateway MT3705 Notebook
Toshiba A135-S4527 will not boot
Could be power supply (ac block and power cord) is dying or died. Laptops are notorious for this.
Aug 01, 2009 | Computers & Internet
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Need help with Vivitar 285 voltage
You should not put AC voltage into DC circuits.
A better directions:
Open open the 285 and solder two wires(red = positive; black = negative) then snake it out to AC connector(this needs to be removed).
Buy 7.2V plug set from Radio Shack or remote control car stores.
Buy 7.2V Battery and Charger.
This will be better than buying the Quantum & cable battery.
It will also wake up the flash faster than using the Quantum.
The total cost should be less than $85.00.
The battery is about 5X stronger than those 4 AA and they do last longer.
eltroman
atdlee@netzero.com
Jan 02, 2009 | Vivitar 285HV Flash
No Power
You know I had a problem like that at sometime back and I found that the CPU unit had come loose I dont how but it did so I pust it back in solid and away everything went. Cost nothing to try just you ego......goodluck
Sep 02, 2007 | Gateway MX6448 Notebook
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
