Question about Kitchen Ranges
Changing out electical outlet
I am changing out elctical outlet from 4 wire to a3 wire outlet need to know how to wire
  • 5,911 Answers
If this is United States standard wiring, newer homes are REQUIRED to have a 4-wire outlet according to the National Electrical Code. If you own a home with this type outlet configuration, its actually illegal to remove it and convert to the 3-wire configuration. Changing the power cord on the appliance is actually an easier option and less expensive (not to mention, you won't be violating any electrical codes). The following link explains how:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and Ground (Green) wires are installed. In a 4-wire configuration, the neutral and ground are independent of each other. Make sure you remove any grounding straps on the terminal block between the ground and neutral.
NOTE: A replacement power cord can be purchased at any hardware store for $20 or less. The cost to have a Certified Electrician install a new outlet for you (if they would) will easily exceed that.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 19, 2009
My wall outlet continues to over heat and melt on the inside... How can i prevent any electic to come thru that one outlet without cutting electricity anywhere else in my home
If the outlet is not being used, there should not be any current going thru it. To remove the outlet from the circuit completely, just turn off the breaker, unscrew the wires from the outlet, and join the wires of the same color using wire nuts.
Feb 14, 2016 | Dryers
I have the GFCI electical outlets in my kitchen. I have the main one and 4 more down stream. I have tried numerous times to reset the outlets. They will reset and work for about 3 minutes and trip...
You should have a licensed electrician fix it. Electricians have test equipment to locate a ground fault. Some hardware stores have a device to test the grounding of an electrical receptacle. It plugs in like any electrical device and shows red or green for good or bad.
However, if you feel adventurous, and your life insurance is paid up.
1. open the circuit breaker at the main panel.
2. Reset the GFCI to verify the power is off (nothing should trip).
3. remove one of the outlets from the circuit. They are in parallel so the wires will need to be connected to feed the downstream receptacles. Splice them carefully and insulate all bare wires. wire nuts are good for that.
4. Turn the power back on.
If the GFCI does not trip, you found the bad one.
If it does trip repeat 1 - 4 as needed.
If this process fails to identify the problem then it is a wiring problem. Consider the electrician.
Dec 21, 2017 | Refrigerators
Electical connection for ru98e
Rinnai RU98e is gas water heater with .4 gallon per minute activation.
This tankless gas water heater plugs into ordinary 120Volt 60 Hz outlet and consumes 63 watts when running.
For electric tankless:
Copy following links for illustrated walk-thru and wire-breaker size calculation for electric:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Oct 31, 2012 | Rinnai Water Heaters
Seams to be a electal problem
1. Make sure that you have power to the unit. Plug something else in the cord or outlet to see if that is the problem.
2. If you are using an extension cord make sure its a 12 Gauge wire size and no more than 100' long.
3. See if the over limit has popped on the motor. If it has push it back in. That will solve it. It is a small button about a 1/4" square.
These are all the easy ones to try first. If that doesnt work let me know.
Jul 02, 2011 | Clarke Power Products Inc AC2001 2HP 4...
I need to know the proper electical connection required for this dryer. is there a schematic available?
The following link explains how to correctly install a power cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Homes built after the year 2000 require the use of a 4-prong power cord and usually have a 4-wire outlet installed. If your home was built prior to that, you can continue to use whatever configuration you have.
Pay particular attention to how the neutral (WHITE) and ground (GREEN or BARE COPPER) wires are terminated between the 3 and 4 wire configurations. In a 3-wire configuration, ground and neutral are connected together at the terminal block. In a 4-wire configuration they are independent of each other.
If you have any questions, please post back and let me know. I hope you find this information helpful.
May 26, 2010 | Kenmore Elite HE4 Electric Dryer
Maytag electrical dryer model # PAV2300AWW power supply layout
The following link explains how to properly connect the power cord to your dryer:
Pay particular attention to WHICH configuration you have. Your power cord will either be a 3-wire or 4-wire configuration. NOTE: If the wires are not color coded, the outer two wires (left and right) will be the HOT leads. The center conductor is the neutral.
If you're new home is equipped with a 4-wire outlet, you are required to update the dryer to a 4-prong power cord to be in compliance with the National Electic Code.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 27, 2010 | Maytag PYE2300AY Electric Dryer
Hook up 4 wire dryer to 3 wire outlet
Hi, The easiest way to do this would be to change the cord to match the outlet. Make sure the cord has the same ground wire that is in your outlet.
If there are any other concerns or you have any more questions, Please let me know.
Vic
Jul 10, 2009 | Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Result problem of 6050
you need to clean it up. first take out the main unit and then take out the transfer/separation unit. clean the wires with alcohol and make sure they dry off before putting it back on. it is more efficent if you change the wires (but gotta get them first of course)
then you should do an image intensity adjustment. about the blur on A3 i must know more details. if the rest of the main unit has toner remains you must vaccum it all. if oroblem persist then check ut the primary corona wire clean it or change it.
Jan 10, 2009 | Canon NP 6050 Copier
Kitchen Ranges Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
