Question about Sony Cyber-Shot DSC-H1 Digital Camera
MY SONY DSC-HI SHUTS DOWN WHEN I REMOVE THE LENS CAP. CAN YOU HELP
SOURCE:
SOURCE: Lens will not retract
I have exactly the same problem and I found out that new batteries solve the problem. I also think the battery charger bundled with the W12 version is not very good. You might try (I haven't yet!) a new charger which handles new types of batteries (Ni-MH).
Posted on Mar 09, 2009
ripleymojica
  • 643 Answers
SOURCE: how do i remove the lens? I need to chkeck the gears.
gears are incased not recommended to open lens assembly. need to order the whole lens assembly including the ribbon cables.
Posted on Jun 02, 2009
  • 11967 Answers
SOURCE: SONY DSC W300 SAYS TURN OFF AND POWER BACK ON AND LENS COVER NOT
Google the words...disassemble a digital camera.
Posted on Sep 17, 2009
lock123
  • 6831 Answers
SOURCE: Even when I take the lens cover off from my Sony
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
ssemul
  • 202 Answers
SOURCE: Sony dsc h1 will turn on in "view" mode, but when
there is some problem with lens block may his adjustment out it can be fix by open you camera and then lens block.after that re adjust lens block hope fully it will work if you do not know how to do then go to near service center.
Posted on Oct 25, 2010
Sony dsc h1 will turn on in "view" mode, but when switched to take a pic the lens clicks a few times and camera shuts down??Tried 3 different sets of new batts from different manufacturers??
Oct 25, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Turn the power off and on again sony cybershot dsc w120
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you !!
Aug 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Camera turns on only for a moment
Thank you!!
Jul 28, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Everytime I turn on my camera a lens error comes up on the display screen, even if the lens is off. It says I need to remove the lens cap every single time and I can no longer take pictures. I can only...
check to see if part of the lens cap snapped off into one of the connection areas or if the lens cap sensor is a button that is stuck down. If not, there may be damage to the electrical and or optical hardware behind the lens.
Dec 02, 2009 | Sony Cybershot DSC-H3 Digital Camera
Powers up then shuts off. Lens is out.
Hi!
There could be two problems:
1. Lens problem - stuck (damaged or sand / dirt inside the reductor and / or lens)
2. Faulty motherboard - happens to the Sony S series cameras.
I'm afraid you will have to give it away for a repair, you should contact your local Sony service center.
I work in a Sony service center and I know what I'm talking about.
Hope this helps!
Tom
Jul 30, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Sony cybershot stopped working..my camera closes down as soon as i open it.i hv dropped it once..also its lens r projected out so what can be solution to open it?
Please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
DSC-P73 problem
In this case i think theres a lens error so i would request u to contact the nearest technician because i think the camera is defective
May 08, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony cyber shot DSC-W1 Digital Camera
I found an online manual for your camera. Page 84 talks about the USB Mode Normal with the 4 dots underneath. It also show a troubleshooting area for this and it is on page 96. Hopefully this will get your camera working right again. Here is the link to the pdf manual. http://www.docs.sony.com/release/DSCW1.pdf
Aug 25, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
