I inherited an Integra portable cooler 62000003 - how does it work? Just put water in and turn it on? Does it leak?
I have one of these, although I haven't used it in years. You just put water in. I never had a problem with leaking. You do have to make sure it's in front of an open window or door and you also have to make sure the filter is clean.
Posted on Jun 28, 2010
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Ultracool Portable Evaporative Cooler CP35--says "no water" but water has been added---how to get it to work.
I have/had the same problem with mine and I know it to be the float as I took it apart and I can get it to work if I remove the circuit, but then if it runs dry and I am not around, I run the risk of burning out the bump. I can't find the replacement part; anyone have a clue where to get parts?
May 29, 2014 | Champion International Champion Cooler...
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
My daughter gave me her portable air con, can't find the manual and was wondering roughly how much water to put in it. Hope someone can help me with this. Thank you.
Mam, you don't put any water in it. This A/C Unit has a dehumidifier in it, that takes humidity/water out of the household air, which helps make the room cooler.
Feb 04, 2011 | Maytag Portable Air Conditioner M6P09S2A
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
Oil in water resovour vw 2002 passat
This is probably a head gasket problem and not an oil cooler problem.
The oil cooler is fairly easy to test.
Remove the cooler from the engine but do not disconnect cooling lines and then pressurize the cooling system. You can use a radiator test tool to put pressure on the cooling system and look for leaks. If it leaks, replace it.
You may also be able to bypass the oil cooler altogether if it leaks.
The head gasket is another story.
Get a 1/4" pipe to spark plug fitting and put a male air coupling fitting in it.
Then you can charge the cylinders with air from your compressor.
Make sure each cylinder that you test is at top dead center so that the valves are closed.
If air bubbles into your coolant, you found your problem.
If air leaks out your intake you have a bad intake valve
If air leaks out your exhaust you have a bad exhaust valve etc.
If you find this useful, please take the time to rate it.
Tim
Apr 15, 2009 | Volkswagen Passat Cars & Trucks
Heating & Cooling Logo
895 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
