Repair error code 5C00 - Office Equipment & Supplies
    President:
  • 2,306 Answers
5C00 is a purge unit error, the purge is the cleaning unit on the right where the printhead parks when shut off. If paper or something is caught in there you get an error, also ink build-up can stop it as well, a damp Q-tip will clean some of the ink away, if it doesn't help you need a new purge assembly.
Posted on Jul 20, 2009
  • 32 Answers
SOURCE: error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
Posted on May 28, 2009
  • 240 Answers
SOURCE: error code on my ix4000 reads 5C00
Canon has a decent trouble shooting guide for this model:
http://www.usa.canon.com/consumer/contro...
Click on the Step-by-Step Troubleshooting link under Tech Support
Unfortunately it does not give any possible solutions for blinking lights.
The user guide on the other hand does.
You can download this under Downloads -> Product / Software Manuals
Here is a summary of what the flashing lights could mean:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Six flashes: No print head installed
Install a print head.
Seven flashes: Print head is defective
Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
Ink used for cleaning is absorbed in the waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact the Customer Care Center as soon as possible. Once the waste ink absorber becomes completely full, printing will no longer be possible.
Nine flashes: Ink tank is not installed properly
Open the print head cover and press the button of the ink tank and reinstall the ink tank properly.
Ten flashes: Battery level is low
Charge the battery. For details on how to charge the battery, refer to the manual supplied with the battery.
Eleven flashes: A specified period of time has lapsed without receiving a response from the digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME/CANCEL button and reconnect the cable.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use digital cameras or digital video camcorders that are compatible with this printer.
POWER lamp flashes alternate green and orange:
An error that requires contacting the Customer Care Center may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it about 10 minutes.
If the problem remains, contact the Customer Care Center.
Posted on Jun 19, 2009
komguy
  • 2306 Answers
SOURCE: Error Code 5c00 for Canon ix4000
5C00 is a purge assembly error, it happens when paper is caught stopping the cleaning blades from working properly, or when the purge unit is just worn out.
Posted on Aug 24, 2009
pineworks
  • 4041 Answers
SOURCE: Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Feb 13, 2010
Canon IX4000 Error 5c00
Error code 5C00 means purge unit is broken, yo have to replace the purge.
Mar 11, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
When i turn the printer on it tells me error code 5c00
Hi andrew_webb0,
The error code 5C00 means the purge unit is broken. To fix this, you have to bring the printer to a Canon service center and need to replace it with new one.
Hope this helps.
Feb 23, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon ix4000 error 5c00
Error code 5C00 means purge unit is broken. You need to bring the printer to the service center to get broken purge unit replace. I hope this short information help you. Thanks.
Find more printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Canon i9950 printer problem error 5c00
According to the Service Manual Error Code List these are the two possible candidates to cause this failure:
- Purge unit (Part-No. QM2-1307)
- Logic board ***’y (Part-No. QM2-1272/QM2-1273)
which means, this device has to go to the service.
(Or to bereplaced)
Best Regards
cominarosa
Mar 04, 2010 | Office Equipment & Supplies
Aug 20, 2009 | Office Equipment & Supplies
Canon selphy ds810 error code
5C00 says that the purge unit is not cycling properly. It's the cleaning unit where the printhead parks. If you can't see something caught in there, it's probably a shop repair...
Jul 27, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Error code 5C00
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Error code problem
Unplug printer. Press and hold power button for about 15 seconds. 5C00 is a hardware service code. Meaning there is an EEPROM error on the printer systemboard. Which may need to be replacing by a certified techinican.
Jun 23, 2007 | Canon SELPHY DS810 InkJet Photo Printer
1,403 people viewed this question
k24674
jasbo
jasbo
