Question about Kenmore Elite 45986 Front Load Washer
Washer stops and flashes F 02. I stop it and
Washer stops and flashes F 02. I stop it and restart. Still have same problem.
  • 5,911 Answers
"F02" is a Long Drain error code. This usually means the drain pump or drain lines are clogged, or you have a pump that is malfunctioning. Restarting the washer will not clear this code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you need to replace the drain pump, they can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. You can use any web source you like, but these, I have found, offer the best service and pricing. Shop all of them for the best price. Just use your model number (located around the door opening) for your search criteria.
Hopefully you won't require any parts. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 19, 2009
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
My washer stops about half-way through the cycle and displays an "02 F" message. I have to pause, then restart in order to complete the cycle. It sometimes does this twice per cycle. Any ideas what could...
This is the problem below.
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
www.appliancehelponline.com
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 STARTS FLASHING WHAT CAN I DO TO STOP
i believe that is the code for slow drain condition.pump may need to be cleaned
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code 02 F
pump is obstructed and needs to be cleaned. Look in this thread for how to clear a duet sport pump trap.
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops at 2 minutes and a letter "f" blinks
I had the same problem. It would flash f then 02,
click this link and you can fix it in about 5 minutes.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
WASHER KEEPS STOPPING DURING CYCLE AND DOOR STAYS LOCKED
Try this I had the same problem and it fixed it when the washer stops it will flash a code I got F 02 but this is really easy and need to be done I wish I had known about it sooner
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
Whirlpool duet ht. pops code f 2
f-02 means long drain. remove panel below door. pump will be in center right in front of you. remove cap and clean out pump. unplug washer first ofcourse
Nov 17, 2007 | Washing Machines
Washer stopped
The computer needs to reset. Try unplugging the machine. Plug it back in and then the system should be able to be restarted.
May 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Squire
