Question about Frigidaire Electric Dryer
My electric dryer has power but does not start..the drum turns with no noise so I doubt it is the motor..the light comes on so it is getting power
    Brigadier General:
  • 4,088 Answers
You need to check the electrical outlet for ~220 volts AC across the two slanted contacts with a voltmeter (if you don't have access to one, maybe a friend has one). If that voltage measures zero, then go to the house electrical panel, find the dryer (pair) of circuit breakers, turn them OFF, then back ON. Recheck for 220 volts as before. If now ok, try the dryer again.
Posted on Jul 19, 2009
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
My electric dryer will not start light works on inside and it will make a noise like it wants to start but nothing happens
If drum turns easily by hand, motor capacitor may have failed - motor will hum but not turn.
If drum difficult to turn, needs bearings or kevlar runner.
Feb 27, 2010 | Dryers
When i turn the dryer on it makes a humming noise but it does not turn on all the way to start- does not start but don't sound like the motor, maybe a sensor? i cleaned out the lent trap..the only light...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 10, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start on the senor light comes on
Hi..
If your dryer does'nt work aat all you need to check this
if it is noise check this
  • Level the dryer
  • Check the drum belt
  • Check the drum support rollers
  • Check the idler pulley
  • Check the glides
  • Check drum bearings
  • Check the blower
  • Check the baffles
Godd luck !!!
Regards
PCmania
Jul 07, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer vibrates with exhaust hose attached
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer has power but drum want turn
check to make sure that nothing is stuck in the blower wheel if nothing is caught then you need a new motor
Dec 19, 2008 | LG DLE2532W Electric Dryer
The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
May 23, 2007 | LG DLE2512W Electric Dryer
Frigidaire  Electric Dryer Logo
158 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
