Question about Acer Cameras
I have an Acer a3 a10.how do I put my photos on to see card from tablet memory?
Have inserted we card but can't figure how to move photos on to it
  • Acer Master
  • 5,936 Answers
Since this is a query regarding a tablet, not a camera, you may find more help if you post it in the Tablets forum.
Posted on Oct 08, 2016
SOURCE:
  • 3 Answers
SOURCE: Photos stuck on integral memory?
When viewing pictures, select the 'Menu' option. Scroll down and on the second page there's a 'copy' function that can either transfer photos from internal memory to a memory card or vice versa.
I didn't know this was possible until today, either. Handy!
Posted on Dec 25, 2007
  • 53 Answers
SOURCE: photo transfer from memory card to acer one laptop
hey! u r stuck to such a simple problem. well not to worry when i'm here.
first of all u check whether ur card is locked??? Check the sides of the card and u will find a small slider, slide it down and then insert into ur card reader.
then open My computer, there u will find written removable drive beside the cd drive or so. open it and u will find ur photos. then single right click on any of the photo, a pop-up menu will appear, select to 'copy' option and then open the drive where u want to paste ur photo, and there again single right click and select 'paste'. and guess what ??? it's done!
hey dude, never forget to rate me!!!!
Posted on Feb 01, 2009
  • 11967 Answers
SOURCE: every time i take a picture on my camera it says
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Posted on Nov 22, 2009
1joester2
  • 74 Answers
SOURCE: I just inserted 4GB Memory card and took only one
http://www.vivitar.com/products/19/ViviCam%205018%20User%20Manual.pdf
Is the manual, and you need to refer to pages 6 and 7.
If you still have problems, you should contact Vivitar support. This should not be a problem since the camera automatically switches to the SD card when inserted.
Posted on Jan 10, 2010
SOURCE: i dont know how to transfer photos from the built in memory to the memory card.
I had the same problem but found the previous solution skipped a few steps for those of us that need to be walked through these things! Here is what I did to transfer the photos I had on the internal memory on my Panasonic Lumiv camera:
Press Menu, use down arrow to move option on left side from "mode" down to "playback" (shows an arrow), then use right arrow to move to list and down arrow to scroll to last item on last page, which is "copy". Press menu to select it, then choose the first choice, which is internal memory to memory stick and push menu and you are done!
Posted on Feb 28, 2010
Acer iconic a3 a10 password reset or factory restore
Pay attention from where he holds the power and volume button.
Oct 18, 2015 | Acer Iconia A3-A10 10.1" Android Tablet -...
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
Trouble with authentication
Authentication means the password is wrong.
May 07, 2014 | Acer Iconia A3-A10 10.1" Android Tablet -...
How do i take a screenshot on an acer tablet
I'm not certain, but I believe that is a function of the Android OS. Mine has an icon which takes a screenshot... and I often do, even when I do not want to. I found nothing about screenshot in the Acer manual, so I am not sure how you can make this a function. The manual is at:
http://www.cellphones.ca/upload/manuals/acer-iconia-a3-manual.pdf I hope that perhaps this can help steer you in the right direction.
Mar 28, 2014 | Acer Iconia A3-A10 10.1" Android Tablet -...
Reset my passoword on my acer iconia A3-A10
How to reset password Acer iconia A3 please help me
Dec 23, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
How do I download pictures and video from my GE DV1 camera to my acer A500 tablet
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Feb 26, 2013 | Computers & Internet
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
Cameras Logo
Top Acer Cameras Experts
Bill DeLisi
Bill DeLisi
Sumeet Sodhi
Joseph Hoffmann
Are you an Acer Camera Expert? Answer questions, earn points and help others
