My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
John,
Is it on a particular Wifi Connection?
Are you able to connect to other Wifi? Or other devices works fine on this particular Wifi Connection?
Go to Settings < Wi-Fi < Click/Tap on the Wi-Fi Network and Choose Forget
Enter the Password again and make new Connections.
It May help.
SOURCE: how does one turn on
Hello.
Sorry, but the Kindle 2 lacks a backlight function according to all reviews found on the
subject.
Hope this helps.
SOURCE: I've only found 1 wi fi network on my kindle and
From the owner of the Wi-Fi network.The password is usually set up in a network router to limit wireless access to authorized people.
If you have no idea what I am talking about, your Kindle probably located a neighbour's wireless internet access point and you cannot use it without his permission.
SOURCE: My kindle wi-fi is not working. I went to turn it
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
SOURCE: kindle is jammed on wi
Firstly, make sure that your kindle is fully charged. Then hold the power switch for 7 seconds. After the light blinks three times, release it. If this does not unfreeze your kindle, hold the power switch for 15 seconds. This should restart your kindle. If neither of these solutions work try contacting amazon kindle support, as they can remotely connec tto your kindle and see what is wrong.
Cheers
Sine Wave
SOURCE: Kindle 3 wi-fi - no response when switched on -
If the 15 second reset does not work, I would suggest contacting amazon. They can connect to your device and see if there is something wrong with your actual kindle. If there is something wrong they are usually pretty good about replacing broken kindled :)
