Question about E-Machines E17T4 17" Flat-Panel TFT-LCD Monitor
Why is it impossible to find a replacement power cord for the emachines E17t4W lcd monitor. Mine was lost inmoving 3 weeks ago and apparently there isn't another one available anywhere on the planet. Emachines is absolutely no help. I've ordered from Ebay and received the wrong cord. Any help is greatly appreciated
  • cskpurple Jul 19, 2009
    I appreciate your super fast response! My monitor requires a 3-prong plug into the monitor, not the more common small, circular plug. Thanks anyway. I'm still looking and googling. Carmen
  • 253 Answers
Http://www.lcdpayless.com/productpage.php?productId=1175,
I found this by googling "e17t4w monitor LCD cord", I would find one from a retailer with a good return policy. if this helps please give a fixya rating, thanks
Posted on Jul 19, 2009
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
Lg w2234s lcd sudenly lost power and wont go back on
power cord connection may be loose at both end tight it
Aug 22, 2010 | LG 22" FLATRON LCD Monitor
Monitor takes anywhere from 15 minutes to more than an hour to produce a display after starting the PC. It starts by flashing briefly on the screen, and eventually produces a display. It works fine after...
Sounds like you have an LCD inverter going out there might be some leaky compasitors on the main board. Its probably cheaper to buy a new one then to have a repair center fix it. Unless you know someone who is good with a sodering iron.
Best of luck and have a happy and safe 4th of July!
Jul 02, 2010 | eMachines E17T4W 17" Monitor
Bought with no power cord. Does this take 120 volts directly to the plug, or is there a power supply that's needed?
Look on the back of the Monitor.
If it has the same power connector as the computer.
Then it is standard 110 60 hz.
If not then you are missing the black box with the transformer and electronics to convert to the monitors proper voltage requirements.
Most flat screen monitors sold in the US are standard 110v/6hz.
And use the same modular power plug.
Oct 31, 2009 | eMachines E17T4W 17" Monitor
Monitor turns pink quite frequently
i think problem is the vga cable of monitor try to remove the cable of your monitor attache to pc or try to reconnect the vga cable
May 21, 2009 | eMachines E17T4W 17" Monitor
What is correct resolution for e17t4w
found correct setting on vista windows support, for emachines flat screen 17". the setting is 1280x720.
Aug 24, 2008 | E-Machines eMachines Monitor E15T4
Computers & Internet Logo
350 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
