Question about JVC KD-G200 CD Player
No sound has something to do with the ignition switch turned to acc, or on and played for a few minutes, and then start the engine, and no sound.
    Problem Solver:
  • 13 Answers
Check all off your car electric system ... may be it's a short circuit or damage...
Posted on Jul 19, 2009
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
All of a sudden my key fob failed on me. I changed the battery and it still doesnt work. Any suggestions??
FIRST CHECK IGNITION IPC BFC ACC 10 AMP FUSE IF ALL LOOKS GOOD. PUT KEY IN THE IGNITION SWITCH.TURN IGNTION SWITCH TO THE ON POSITION FOR 10 MINUTES UNTIL THE SECURITY LIGHT DISAPPEAR TURN ITSELF OFF,THEN TURN OFF IGNITION SWITCH FOR 5 SECONDS THEN TRY START THE ENGINE.
Jul 20, 2011 | 1999 Oldsmobile Alero
With engine started and foot on brake truck will not come out of park. will come out of park with ignition switch turned to the first notch but engine not running. with ignition switch turned to first...
Sounds like your brake lockout switch is bad. The brake lockout switch on many vehicles is used to prevent accidentally shifting the trans into gear. The fact that you can shift with the key in the ACC position is a dead giveaway. Good luck.
Jun 12, 2011 | Chevrolet C1500 Cars & Trucks
Taurus 96, electrical problem, clicking sound, engine cranks
close, there is an emergeny fuel shutoff switch hidden in the trunk of these things burried under the carpeting, you probably have something resting on it OR water got on it and is shorting it out, my friend had a 92 taurus 3L and the switch was in the trunk, 14 inches off the trunk floor on the drivers side wall, should be a small **** in the carpeting you can push your finger through and feel it.
Feb 25, 2010 | 1996 Ford Taurus
I have a 1994 ford bronco with a 5.8 351w. when ignition is turned to accessories the fuel pump will come on for 2-3 sweconds then go off,but after a few minutes it will come on and stay on. when the...
Take your Bronco to an Autozone or Oreillys for a free scan. Offhand a new ignition switch would seem like a good idea, because the fuelpump should not be working in the ACC position.
If a new ignition switch does not help the fuelpump problem the pump is wired to an accessory. You need to look up the fuse info in an owners manual.
Dec 01, 2009 | 1989 Ford F 150
Audi A6 Manual trans.1.8 T key will not stay in ACC position.To play radio with engine off you have to hold the key in the passed start position.
sounds like that ignition switch is broken or maybe a blown fuse, check all your fuses start there if all fuses are good then switch is the problem, good luck.
Oct 31, 2009 | Audi A6 Cars & Trucks
Basslink works in 'on' but not when the engine is running
check your amps ground wire i had similar prob the vibration from engine caused the wire to move interupting the current
Jul 19, 2009 | Infinity BASSLINK Car Subwoofer
My 1996 Pontiac Sunfire wont crank...
tryy replacing the fule injectors and the fuel pump could possibly be shot as well. you have a fuel problem.
May 07, 2009 | 1996 Pontiac Sunfire
JVC KD-G200 CD Player Logo
76 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
