Question about Whirlpool LEQ8000JQ Electric Dryer
Dryer won't dry
Fairly new LEQ800JQ dryer is taking 2+ hours to dry a load of clothes. The clothes are hot when I check them and the drum turns. When it was working like it should the lint screen would fill up with lint from top to bottom. Now the lint screen only gets a little clump of lint at the bottom of the screen.
  • Gevallia Nov 26, 2007
    That fixed it. Thanks for the help.
  • 240 Answers
Sounds like a ventilation issue. Remove the dryer vent tube and take a leaf blower to it and try to blow it out as best as you can. Also check outside to see if something is blocking the vent. Birds and mice love to build nests in that nice warm vent tube. The ole leaf blower will remove these nice little woodland creatures with force, yet its totally humane, and wont hurt them a bit. If this doesnt work, you may have to run to your local building supply center or hardware store and get one of those inexpensive brushes that you can use to clean out your lint areas. A good test to see if you have good airflow is to remove your lint filter (if its a top filter), turn on the unit, and drop a small piece of lint down the tunnel. If it zooms right down, then its good. If it just kinda hangs around, its not that good. If you have a way to check the entire length of the vent tube, look to be sure that there is no dips or kinks. Also, remember that the shortest and straightest vent tube, is the best vent tube. Let me know how it turns out, or if you need further information. Good Luck!!!! Jim
Posted on Nov 21, 2007
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Taking 2 to 3 hours to dry a load of clothes...checked dryer vent from dryer to outside and it is not clogged.. what can the problem be?
Are the clothes hot when you take them out? If not, then maybe your heating element is broken. Easy to replace that, just pick one up from a parts store.
Our dryer started to take a long time to dry clothes but the heating element was working. We opened it up to check for lint and so on, and it turned out that the drum had slipped slightly out of location and the back of the dryer was partially obstructing the duct. That was probably what was making the dryer squeak, too. We reseated the drum easily in a few seconds and now it dries well again.
Feb 18, 2011 | Dryers
It is taking over 2 hours to dry a load of clothes. I stopped the cycle and opened the door to check the clothes. The dryer smelled like something was burning but no visible smoke. This is a fairly new...
Sounds like the vent is clogged with lint. You should have the vent cleaned once a year to keep the appliance operating properly. Also, make sure there are no kinks in the vent line.
Jan 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 | Dryers
Whirlpool LEQ8000JQ Electric Dryer Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
