Question about Penguin Nebulizer Neb U Tyke Ic Nebulizer Compressor! Brand
The liquid is not evapourating - Penguin Nebulizer Neb U Tyke Ic Nebulizer Compressor! Brand
  • morriclan May 11, 2010
    Can you feel air blowing through the tubing coming off the nebuliser? Is the nebuliser making the correct noise?
I have two lift master remotes. When it gets cold one remote stops working where as the other one works fine. If I heat the remote up in my hands for a minute it works. I had the battery tested and it...
get some electrical contact cleaning spray from halfords, remove the battery and give it a good spray, don't worry its tottaly harmeless, when its saturated operate the buttons quite a few times and then allow all the liquid to evapourate, use a hair dryer to speed this up, then give it a go.
Dec 07, 2013 | Building Materials
"no disk" message, intermittently plays disks.
sounds like the eye is dirty use a little rubbbing alcohol and a soft lint free cloth (like you use for cleaning glasses and wipe the eye area clean DO NOT USE WATER TO CLEAN THE EYE ) rubbing alcohol evapourates quickly water doesn't
Sep 21, 2013 | Audio Players & Recorders
Refrigerator overflows from evaporator pan
you have a blocked drain from the rear of your refriderator to the motor drip tray
the heat from the motor evapourates the water,
get some wipper snipper cord and push though the rear drain located inside
the refridgerator behind the plastic captulator and it will open the bockage
Dec 27, 2011 | Refrigerators
The freezer is cool but not frozen
u'r defrost time clock needs replacing if u have a defrost refrig , u'r fridge is psobably warm as wellOR u do have a freon problem OR COMPRESSOR loosing capacity , it doesnt seem good for u :(
if its a defrost problem the freezer will be all frozen up and the fridge will be not cold
Oct 16, 2010 | Samsung Refrigerators
Why is water coming from the thermistor
THE DRIP TRAY / DRAIN FROM YOUR EVAPOURATOR IS BLOCKED
Oct 16, 2010 | Heating & Cooling
Leaks onto floor from evapouration area (12cuft model)
check if the door is closing properly and the gasket is not worn out or hanging from the door
Jun 16, 2010 | Woods Upright Freezer V1613RW3
Drain fuel tank
HI MATE TAKE OFF THE FUEL PIPE TO DRAIN THE TANK THEN PUT THE PIPE BACK ON TURN THE FUEL OFF AND THEN LEAVE THE FUEL CAP OF BECAUSE PETROL EVAPOURATES SO THE ACCESS FUEL WILL EVAPOURATE AND ALSO MAKE SURE YOU DONT GET ANY FUEL ON THE PAINT THE PAINT WILL PEAL OFF ELSE
Aug 25, 2009 | 2005 Honda VT 750 Shadow Aero
Leak - water not evapourating
check your doors may be not clossing (ajar) or check control to high
Apr 02, 2009 | Westinghouse Refrigerators
Penguin Nebulizer Neb U Tyke Ic Nebulizer Compressor! Brand Logo
41 people viewed this question
Top Penguin Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Penguin Health and Beauty Expert? Answer questions, earn points and help others
