Question about Car Audio & Video
I dont know the value
A resistor has gone out in mine and i dint know the origanal value of it [URL=http://entertainment.webshots.com/photo/2650206940105376167OMJqni][IMG]http://thumb7.webshots.net/t/75/75/2/6/94/2650206940105376167OMJqni_th.jpg[/IMG][/URL]
  • spikezeek194 Jul 19, 2009
    thats what i need
  • brownleopard
    brownleopard May 11, 2010
    Could you please post a clearer, closer photo? It looks almost like a variable resistor.
I packed it full of c-4 and now its perfect
Posted on Jul 19, 2009
I have electrolux washing machine EWF10741 one resistor on the control board was burned out R57 What is the Value of that resistor?
I have the same fault. I'm in Malaysia. The R57 is the blow out resistor for the "compter section of the board. Mine appears to have been caused by the Transient Voltage suppressor clamping. TRSB1 and possibly the diode (ultra fast rectifier) D5.. Did you find the resistor value?
Sep 05, 2016 | Electrolux Washing Machines
Can anyone tell me the value of the resistor in a Kitchenaid K5A mixer. I think mine grew legs and walked away. Thanks, Mike
Are there any colors on the resistor or it is missing. If you know what the voltage and current should be in the circuit you can calculate the resistor value.
May 08, 2014 | KitchenAid K45SS Classic Stand Mixer
2 resistors are burnt rz126 and rz125 but i dont know the value of these resistors samsung SPA43W6HPX
Both of those resistors are 3.9 ohm 2watt metal film resistors for the convergence ICs. The ICs will most likely need replacement as well.
Mar 03, 2011 | Samsung HCL4715W 47" Rear Projection...
Tv-raster comes for 2 secondsthen gone.checkedpower supply-3caps bulged,changed no chnge.would it be in p/s?. patrick c.thank you
Check the components in thi mini board ( neck of tV picture tube ) resistors might have gone high in value.check with meter. replace. It is preferable if you open one leg and test. Keepin in circuit it may not give you correct values. Values are generally printed on the resistor body or follow the colour coding.
Aug 21, 2010 | Beko 324250WN 28" TV
On the circuit, one of the resistors got blown up
U can see one or two bands of the colors of the resistor right?Compare it to a couple resistors beside it or around in the board.U should know and determine it values.
May 04, 2010 | Sharp 27R-S50 27" TV
What is the value of the large resistor on a KW14-VO board
I overheated my current limiter too, so the colored bands are unreadable. But I measured it at 6.2 ohms. The wattage on this resistor is not really high enough for the job, so they get very hot. I replaced mine with a 10W resistor (too big for board mounting) attached to the board with 22 ga. wires. I clipped a heatsink around the resistor and stuffed it into the empty space at the back of the housing. Hopt this helps.
Apr 15, 2010 | Ryobi Drills
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Mar 09, 2009 | Computers & Internet
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
