Question about Samsung DVD Camcorder
I am having problems finalizing my disk to play back on external device. I have the DVD-Rw disk and it was initialized in video mode. When I go into function, menu, disk operations, the only option I'm given is to initialize the disk again. I have the Canon DC320.
  • denise mcgurl Apr 27, 2012
    I have the same problem. DVD RW disks tell me to initialize again (instead of finalize). I'm afraid if I do it, it will erase everything. Did you ever find a solution?
To have finalize option, please put the camera into video mode; that means not to be on picture mode.
Posted on Nov 22, 2009
    New Friend:
  • 53 Answers
On my Canon DC320 the camcorder has to be in PLAY mode before the FINALIZE option will be available.
Posted on Jul 21, 2012
SOURCE:
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
Need to unfinalize disks. I had them finalized and they will not unfinalize so that I can use the disk again.
If your mini DVD disk is a DVD-RW (or DVD+RW) and it had (previously) been finalized in the VR (or Video) mode, simply select the "unfinalize" option ... (in DISC - Camera mode, from the MENU - Disc Manager - Disc Unfinalize ) ... as in p. 82 of your manual.
If you do not want the video data on the DVD-RW disk anymore, you can simply re-format the disk again, so you can re-use the disk.
Jun 10, 2010 | Samsung SC-DC173 DVD Camcorder
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Canon DC230, DVD-R: Won't initialize or finalize
Try the Canon DVD-RW I have had no problems. Any other discs will NOT work, Sony, Memorex, Fugi etc
Dec 29, 2008 | Video Cameras
Dvd recorder
Hi Nickstart, start checking if the problem is related with the kind of Disk and test on different brands, disk types.
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
Your DVD supports the following DVDs -R, -RW, -RAM, all -R disks are supported both on 3'' and 5''.
On +R it just writes regular DVD +R, DVD +RW and mini DVD +R are not listed in DVD specs, therefore are not supported on writing.
When your unit records DVD +R it changes the format to DVD-V, The usint does not support DVD+RV.
I assume it works better with -R
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
See also the manual here, at page 6 and 7 it also says: "Play may be impossible on some DVD-RW (DVD Video Recording format), +RW, CD-R or CD-RW discs due to the condition of the
recording."
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Sep 08, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Blank DVD discs that used to be recognised are suddenly not able to be read
I've found that once a disk is formatted in certain formats with a pc it prevents the LG from reading it.  Format it again in the LG (if you can!) or use the pc to format it using the UDF1.5 setting in a pc (which sort of resets it so the LG can at least see it as an unused disc again).
All in all I have found my RH19991H really confusing as far as disk initialization and formatting and finalizing is concerned.  Sometimes you can select to finalize a +-rw dvd and sometimes not (the latter is the the case according to the manual) and sometimes I can select the format mode and sometimes not.  Sometimes the machine auto finalizes the dvd+-rw (the way it should be says the manual) and sometimes it does not and then I cannot use it in the pc.  I have also created some disks with DivX files and was able to play them in the LG and then using the same pc, same type of discs, same video editing software and same settings created other DivX files I could not play on the LG.  It seems the software on the machine needs some work...
Oct 14, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Finalizing Discs
The only reason that you have to finalize a DVD-R disc is so that you can play it back in an external DVD. Once finalized, you can no longer add motion video to that particular disc. Discs that are not finalized can still be played back when inserted in the DVD-camcorder.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Samsung DVD Camcorder Logo
599 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
