Question about Epson Stylus CX6600 All-In-One InkJet Printer
Color of prints very faint
Was fine yesterday
  • Epson Master
  • 1,879 Answers
It is unfortunate that you are having this difficulty with your printer.
To help preserve the life of the ink cartridges we suggest that you turn the printer off when it is not in use.
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
Posted on Jan 23, 2008
Black not printing properly. Sketchy, and faint. 2 new cartridges put in in 24 hours. Is my print head going? Color works fine
take a moist (from water) paper towel lightly rub the print heads and clean off the heads. hope that fixes it.
Dec 07, 2011 | Lexmark X2670 All-In-One Printer
Faint print
Check the print driver settings, this may need to be changed.
Also clean the cartridge nozzle with damp paper towel - should work.
You can service the device in the driver properties.
Jul 09, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Faint lines on printing
Keep running the nozzle cleaning. It should eventually sort itself out. Also try aligning the print heads.
Jul 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
2600n prints greenish little reds
i have priner hp laser jet 2600n but it is printing very low any pic if i print it is come very low color i changed toner cart but still same problem.
Sep 03, 2008 | HP Color LaserJet 2600n Printer
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Colours printing really faint
dear sir you should check the colour mixing detect sensor
Sep 26, 2007 | Epson AcuLaser C900 Printer
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
