Question about HP Color LaserJet 2600n Printer
Loud noise When powering up, during "calibrating" and whilst printing there is a very loud mechanical grinding type noise. I have checked all gears/moving parts etc and can find nothing wrong, the printer does work but the noise is unbearable. Any ideas/fixes...???
Re: Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Posted on Nov 20, 2007
0 characters
3 Points
What causes a loud grinding noise when I print?
Can you provide the model of the Dell Printer you have that is making a loud grinding noise. I can the search for resolutions to this issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 27, 2016 | Dell Printers & Copiers
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Grinding noise
I just chatted with Dell support about this since I have the same problem of the grinding noise on my C1760NW Dell printer. I have it plugged into an APC backup battery which acts like surge protector (unless power goes out then battery kicks in). He said the printer needs more power and that surge protectors and battery backups are not good for this printer since they restrict the power which sends less power to the motor and fuser than what it was designed for. So with less power from the APC backup/surge protector, the motor moves very slow and may not fuser the toner to the page correctly and can cause permanent damage over time. So I plugged into the wall directly instead and the grinding noise went away immediately even when printing 10-15 pages right after plugging into wall, but then the noise came back when I printed a bigger job. So for now I'm letting it cool down for a couple hours and crossing my fingers that the damage is not permanent. So... answer is plug it into the wall directly for maximum power and hope that your printer is not permanently damaged. By the well, Dell support chat was awesome.
Mar 11, 2014 | Dell, Inc Dell Color Printer C1760nw -...
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
HP CP3525 loud grinding noise when calibrating after printing
Sounds like you have a stripped gear somewhere. Probably somewhere in the paper drive assembly. Take it to your nearest printer repair shop, because tech support may not be much help with that.
May 20, 2011 | HP CP3525N Color LaserJet Printer
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
HP2840 All-In-One. Makes loud squealing noise when calibrating & printing. As if it needs oiling.
thy taking the imaging drum out and power cycle. If the noise goes away replace it. If the noise persist it might be the carousel
Aug 24, 2010 | HP LaserJet 2840 All-In-One Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Officejet 6210 noisy rollers
i believed this issue is on the mechanical side of the printer.if the grinding noise is very noisy if you still have the warranty of the printer you can go ahead an ask for the replacement of the printer coz it is an issue with the mechanical part of the printer..
Aug 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
760 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
