Question about HP PSC 1210 All-In-One InkJet Printer
I have 2 hp 1210 all-in-one printers one works fine the other will not print so I know that my cords and usb ports are fine and went thru the troubleshooting guide without success
  • Paul Blessing May 11, 2010
    Hi.. Did you try rebooting after switching printers? Lets fix this if youv'e got one that works.
  • 253 Answers
Change the cartridge from the one that works to the one that doesnt, the printheads, (usually on the cartridge can go bad, if this helps please give a fixya rating, thanks for the question
Posted on Jul 19, 2009
My printer HP psc 1210 sys it is
When the system is unable to recognize the printer "offline" appears on printer icon. 1. Ensure that printer should be on condition.
2. Check printer USB cable both ends are properly connected or not, remove & re-fix .3. Insert in another USB port. 4. Replace with another USB cable.5. Replace Formatter assembly.(only professionals can do this activity)
Nov 29, 2011 | HP PSC 1210 All-In-One InkJet Printer
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Prints but can't read it
Buy a new ink Cartridge.
Take it out shake it a bit, put it back, if it prints darker for a little bit. You need a new ink cartridge..
Oct 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 1210 wont print
Disconnect the USB cable > click on start > Run > In the run box type services.msc and press OK.
> It will open services window > right click on print spool er > click on start.
Now connect the USB cable and try to print.
Sep 16, 2008 | HP PSC 1210v All-In-One InkJet Printer
HP PSC 1210 does not print at all
i dought dust would cause that, reboot pc and unplug printer
plug printer back in then turn computer back on, if still doesnt work try a different usb port
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
PC power resets w/ HP PSC 1210 plugged in
one of these updates causes a conflict more than likely a microsoft hotfix, try using a different usb port and unplug and plug printer back in
HP PSC will not print
Click Start (windows) icon - Control Panel - Printers. Right click on the HP PSC icon. Set the printer as default printer. Right click on the printer icon and select Set as default. Right click on the printer icon - Select properties - Click on Ports tab - Change the port to USB virtual printer port. Click Apply and Ok. Try to print. If the issue did not resolve. Get back to me.
Dec 11, 2007 | HP PSC 1210 All-In-One InkJet Printer
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
My hp psc 1210 won't work with vista
I had a similar problem! Here is what eventually worked for me, after searching through postings for hours on end...
First, I made sure I had the new driver. Second, (and this might be different for you), my computer recognized my printer, but any time I sent something to print, it never made its way there. The little printer icon at the bottom said 1 document pending, then quickly said 0 documents pending, but nothing ever printed. When I ran HP diagnostics, it said everything was okay with the printer, and even printed a test page! But still nothing from any other program. So, eventually I went to control panel, then printers, then I clicked on the HP printer, then right clicked and went to properties. I changed two things in here, and I'm not sure which one was the solution. First, I changed the security settings (in the security tab) so that every user had access to all options for the printer. Second, on the advanced tab, I selected print directly to printer instead of the spool print documents option. And tada it worked!
May not solve anyone elses problem, but I didn't see this solution in any of the posting sites, so I thought I'd share it. Give it a try!
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
