Question about Garmin Nuvi 350 Car GPS Receiver
Audio jack damaged on Lowrance XOG
I tried to walk away from motorcycle with my headphones still plugged into the xog. Now I don't get any sound from the units built in speaker, and the headphones will only work on one side. There is no visible damage from the outside but obviously the 3.5 mm jack is damaged inside. Is it worth trying to fix it or should I just get a new gps
    Brigadier General:
  • 4,090 Answers
The cost of fixing may well exceed the cost of a new unit 110 for the board and 90 an hour 2 hrs minimum
Posted on Jul 22, 2009
Screen buttons work only on one side
hi codeyvet have you tried calabrating the device this should put it right /on startup it should give you this option goodluck
Jan 30, 2011 | Lowrance XOG GPS Receiver
BAttery problems - my Xog only lasts about 10 minutes. Is there a replacement battery that can be purchased?
A battery that will fit is available http://www.batterybob.com/product.asp?intProdID=661221
The good news is that it has 25% more power than the original. The not so good news is that you will have to replace the plug on the new battery with the one from the old battery. If this is not something you want to attempt take the old battery to Batteries Plus, they will sell you a new battery and take the plug off your old battey and put it on the new battery.
Jan 11, 2011 | Lowrance XOG GPS Receiver
Is this product repairable? Does not come on when plugged into the power source.
Before you can tell if it is repairable or not, you need to carry out some tests before you conclude what the problem is.
Insert your battery in another lowrance gps, then charge it for about 2 hours then power it on, if it comes on, then the fault is not from the battery, but if it does not come on, then it means the battery is bad and need to be replaced with a new one.
Test your charger by trying to use it on another lowrance gps device to see if it will charge. If it charges, then the charger is alright, but if it does not, then the problem is that the charger is bad and need to be replaced.
If both seem to be okay, then you need to test the gps device by connecting it to a computer to see if it will work, if it does not connect then there is a problem with the connecting port or there is an internal problem that can be solved by disassembling the device.
Dec 24, 2010 | Lowrance XOG GPS Receiver
Need a battery to replace a maxell ICP653443 for a tomtom one gps
Maxell 653443 battery has a very thin black plug, all the so called replacements have a white plug that is twice as thick. Where can I find the exact replacement?
Oct 21, 2010 | Lowrance XOG GPS Receiver
My Xog GPS will not hold a charge. With low batt it keeps turning on then shutting off --- until the batt is totally dead what do i do
Get a new battery at Batteries Plus. Take the GPS in and they have to switch the connecter end from the old battery with the one on the new battery (part # PDA-192LI) and put the unit back together and everything will work fine. I just did it today. The cost was $25.19 :)
Aug 12, 2010 | Lowrance XOG GPS Receiver
Once I downloaded 1.8 update how do I delete the card?
I am assuming you mean your SD card with the 1.8 update on it. Just put in your computer and delete the update or reformat it.
Jul 02, 2010 | Lowrance XOG GPS Receiver
How do i change the internal battery in a xog gps
There are four screws on the back (phillips #0) to unscrew. Batteries Plus has a replacement battery (part # PDA-192LI) they will have to change the connector from the old battery to the new battery. Plug it in and put it back together and it will work fine.
Jun 30, 2010 | Lowrance XOG GPS Receiver
Help me need to know how to put muci on my gps
The easiest way to put music on the GPS is to put it on a SD card
Jan 11, 2010 | Lowrance XOG GPS Receiver
Exact same thing
Try saving the update to a SD card and put that in the SD slot of the XOG
Jun 12, 2009 | Lowrance XOG GPS Receiver
GPS Does not work
If you have a memory card inserted, remove it...if the problem goes away, try replacing that card. If the problem occurs with any card then...
Try installing the latest update from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
even if you already had the latest...try installing it again.
If the problem occurs with any card, and after updating or attempting to update, there is a probably a malfunction with the XOG and it will need to be repaired/replaced. The Lowrance contact by phone is 800-324-1356 and go to http://www.lowrance.com/en/Support/Product-Support/Contact/ to email them.
Apr 11, 2009 | Lowrance XOG GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
91 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
