Question about Arris WR850G Router (DHWR850G)
How can i get in through the gui ??
How can i get in through the gui if i tried already with the 192.168.1.254 or the defaut gateway
  • brownleopard
    brownleopard May 11, 2010
    Are you trying to get in via wireless or wired?
  • 442 Answers
Please follow the manual - here is the link for the manual in case you do not have it.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
Do not reset the modem untill you have your ISP or techsupport personnel contact number handy.
Posted on Jul 19, 2009
Where can I find my wireless key?
Try to access your router's gui. To do this, you have to use your internet explorer.
1. Get your default gateway address first. a. press the windows key + R b. type cmd then press ok c. on the black screen type ipconfig then press enter d. look for the default gateway address 2. Type the default gateway address on the internet explorer address bar and you will be able to see your router's gui
3. Refer to the manual posted on the link below. Refer to Chapter 7 to get the WEP key of your router.
note: you need to connect wired to your router before anything else.
Netopia Wireless Router Manual
Jul 08, 2011 | Netopia (3347NWG-VGX) Wireless Router...
WRT4G2 VI wireless router. I was upating the firmware when the power flashed. I have no access to the router's gui and the router is not broadcasting. I am not getting a dhcp address
do a hard reset for the router by pressing the reset button for 10-20 seconds...
check whether its getting a dhcp address...
if it is still not getting an ip address, then try to assign a static ip address in the range of your router on your computer...
for example...
The default ip address of linksys is 192.168.1.1.............
then assign
IP address 192.168.1.5
Subnet mask 255.255.255.0
Default gateway 192.168.1.1
Also assign a static DNS
Primary DNS : 8.8.8.8
Secondary DNS : 8.8.4.4
Now try to open the GUI of your router...
Dec 10, 2010 | Linksys WRT54G2 Wireless Router
I'm trying to configure my Cisco WAP4410N Wireless-N Access Point and i cant access the login page to do it. My IP is already set to 192.168.1.# so i thought i would be fine but it still doesnt work
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Nov 03, 2010 | Linksys Cisco Small Business WAP4410N...
Want to change user name and pass word
You can do so by opening the GUI page of the router:
First connect it to the computer through a Ethernet wire and then check the default gateway (go to command prompt and type ipconfig)
put in the default gateway address in the internet explorer address bar
Log in to GUI..the default username and password is following
Username: admin
Password: admin
or
Username: admin
Password: password
Log in and change the username and pasword...you would also be able to change the wireless password (WEP key) from same
Sep 25, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
How do you change the NAT
NAT (number addressing translation) it is a setting for router or gateway,and needs to be open
you can change the settings of your router/gateway via GUI (graphical user interface) now it will depend on your router manufacturer
Jun 13, 2010 | Microsoft Xbox 360 Console
HAVE A 327W HOW DO GET IT TURN ON WARELESS
Check the IP of the modem, follow this steps: If you are using a Windows OS.
1. Click Start then select Run
2. On the Run box type in "cmd" then press Enter
3. It will launch a DOS window
4. On the command prompt where the blinking line is type in IPCONFIG the press enter.
5. get the Default Gateway
Access the modem's GUI by following this steps and configuring the Wireless (the gui would depend where your modem came from but the steps should be at least close to this)
1. Open Internet Explorer or any browser that you have
2. Go to the Address bar and type in the Default Gateway
3. On the login screen type your UN and PW that was set for the 327W
4. Once you are on the modems GUI and look for the wireless tab.
5. Click on the Wireless tab and it should indicate if the Wireless is Enable or Not.
* If it is disable locate for the Configure Button. There is an option to Enable the wireless connection.
Sep 23, 2009 | Computers & Internet
Need default gateway
try IPconfig/all
usually the defaut gatway is the router own address. i.e. 192.168.0.1 or 192.168.1.1
May 20, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
How do i change my password
hi,
access the router GUI by typing in the default gateway in the address bar of IE. Default gateway can be found by-- typing ipconfig in the command prompt window..
Reconfigure the modem... for the wireless network... Select your home network name and then enter your home network access password... or edit it...
good luck
was i helpful?
Nov 22, 2008 | D-Link AirPlus DI-524 Wireless Router
3com officeconnect wireless 11g cable/dsl router
router default ip gateway will be the 192.168.1.1,so you can able to give the same ip address,so you configure only other ip address & try it.
May 25, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Arris WR850G Router (DHWR850G) Logo
79 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
