Question about Maytag Refrigerators
How do you reset the control panel on a Maytag refrigerator, model #MFI2569YEM0
The control panel is blank, all lights light up if you push a button, tone when you push lever for ice/water.
  • Michael Adler
    Michael Adler Oct 14, 2018
    I have the same problem. Any fix?
  • Bryan Curtis
    Bryan Curtis May 19, 2019
    Any fix for this???
    New Friend:
I need to rest my control panel , I just put in a new one model #mfi2569yem2 how do I do this
Posted on Oct 17, 2018
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Try unplugging for 5 minutes
Posted on Oct 14, 2018
SOURCE:
tborn6
  • 700 Answers
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Posted on Apr 03, 2009
aasc
  • 1606 Answers
SOURCE: After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Posted on Jul 19, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Posted on Mar 11, 2010
SOURCE: Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Posted on Mar 30, 2011
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Jul 24, 2009 | Refrigerators
No Water or Ice
It sounds like a control board problem. When you push in the paddle does the fan in the freezer slow down? If so you need the control board on the back.
Apr 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Sep 24, 2007 | Refrigerators
Refrigerators Logo
6,869 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
