Rheem furnaace blower stays on
Good morning
I'm hoping one of your experts can help me ...
I have a Rheem gas fired forced air RGAA-1000. I replaced an old manual thermostat with a programmable Ritetemp during the summer. It seemed to woked fine. Now that it is colder and I've switched to heat, I've noticed the fan stays on even when the heat/cool is in the off position on the thermostat. I changed the thermostate to a Lux, that I like very much.
I've tried a few things I've read on-line thus far:
Adjusting the on/off/limit by moving the switch on the off all the way down then back up until the fan went off. This worked once. Also the first time I only touched the knob the fan went off.
Connected the blue wire to (B). The fan shut off when I lowered the temp, but I did not want to harm anything, so, I changed it back.
Right now I have the wiring as below:
furnace wire (connection on thermostat)
red (Rh)
white (W)
green (G)
Any ideas for me?
  • 80 Answers
Wiring is ok but should have a yellow wire to y this for your compressor and blue should go to b
Posted on Dec 19, 2007
  • 447 Answers
On a furnace the fan is controlled by a computer and a sensor ot a oldstyle fan thermostat. Basically it waits till the furnace heats up a little and then turns it on and after it shuts off it will run till the thermostat cools back down may take a few mins. In cool mode the thermostat controls the fan so it shuts down immediatly. This is why the thermostat asks you if its electric or gas heat. Should have a switch somewhere for this.
Posted on Nov 19, 2007
Hi, I have a Rheem RHSA HM4221JA air handler with
Sounds like a relay inside the air handler is stuck 'closed'...
Oct 17, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
GX90-715A wont stay fired
1) Product manual has burner info page 11, maintenance 12, and troubleshoot flow charts starting page 17
Otherwise, Rheem does not post service manuals.
2) Post question on pro water heater forum.
3) Is air intake clear? Is the burner sooted? Is the flame large and clear blue? Is the vent obstructed? Does air draft when blower activates?
Feb 14, 2013 | Rheem RUUD GX90-715A Water Heater,gas,90...
I have a Rheem 41VRP50N water heater. The water I am getting is luke warm on a good day. The burner fires up when I turn the thermostat to the highest temperature only. I drained the unit and flushed...
This condition can be caused by 4 different problems, or combination of these problems.
Good indicator would be to check temperature of water inside tank.
Put bucket under TP overflow tube and release water into bucket, then use cooking thermometer to gauge temperature. Stand back from scalding water that can shoot out of overflow.
If tank temperature is 120-130:
1) Crossover is suspect:
If tank temperature is low:
2) Bad gas control valve thermostat is suspect.
I believe Rheem 41VRP50N has Honeywell or White Rodgers electronic gas control valve.
Open following link to identify gas control thermostat and see typical error codes.
Replacement gas valve can be purchased from Rheem.
3) Combustion parts and tubes need cleaning, and bleed gas line for air and water contaminants.
4) Water heater has sediment build-up coating burner transfer surface and covering thermostat.
Year of manufacture for Rheem water heater is 2nd two digits of serial number, so XX03.. would be 2003.
Add a comment and say what you did to solve problem.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Rheem Water Heaters
I have a 5v40 hot water heater. I lite the pilot and burner work fine as long as i have the door open to get air. close the door and the pilot lite and burner goes out. starved for air. there looks like...
Probably don't have good news for do-it-yourself repair.
Richmond is Rheem.
Rheem gas water heater manuals say to call service technician if the combustion chamber FV sensor has tripped, or if water heater has flooded.
FV trip requires part replacement, and flooded heater has to be replaced.
I read one thread that might help:
I posted same question on pro water heater forums, and the plumbers will not man up and tell how to replace the part. They cite legal issue because gas water heater is dangerous, period.
They have a point, but I am still looking for a good DIY answer.
If repairs are more than $330, then buy a new heater at local box store and install yourself same day.
Upvote the help.
May 17, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Working on a 3yr old rheem water tank 22v50f1, pilot doesn't stay on, replace theromcouple and problem persist, cleaned air intake screen... what do ???
Sorry to read about your problem, I hope this helps you out.
That means you gas control valve is defective....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem model RGAA-125A .Air conditioner works. When I put on heat fan doesn't blow
The heat relay on the main control board is bad...
You will have to replace the control board...
Sep 26, 2010 | Heating & Cooling
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
I have a ruud oil forced air furnace, but the model # says it is a Rheem ROBC-130. My problem is that the blower motor runs all the time, the furnace will fire and run for about a minute then shut off it...
this is more than a fan control relay . it is a black relay that will appear to have several wires connected to it but those wires connect to the base ,it unplugs , if it is set up for ac it might have 2 relays one toward the front one toward the rear replace the front one first ,,, if on good replace one @ rear should fix if not let me know
Dec 27, 2008 | Water Heaters
Heating & Cooling Logo
609 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
