Question about Lexmark Wheelwriter 15 Series II Typewriter
The unit will not get past the startup stage
Whelwriter 15- The lights stay on the right hand side and wont turn off. There is keyboard functions in any way.
    President:
  • 566 Answers
The answer to your question is given in the operating instrctions for your typewriter, you can download from Lexmark site, here:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
If all lights stay on, turn the typewriter off, wait 30 seconds, then turn the typewriter on again. If and the lights are still on, call for service.
Posted on Jul 24, 2009
My right side turn signals work properly but my left side turn signals don't function. I changed the bulb in the front signal but it didn't do anything...I'm stuck!!
swap the right bulbs to the left side for an easy check. if not the bulbs then will have to start checking connectors and or wiring.
Mar 21, 2015 | 2001 Harley Davidson XL 1200 C Sportster...
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
Turn signal
Check the earthing of the left hand side blinkers first both front and rear, since the right hand side is functioning we can rule out tht the flasher unit is ok.
Not bad too to check the bulbs of the left side blinkers if they are of the required voltage and watts both front and rear.
Hope this helps!
Jul 09, 2009 | 1983 Yamaha XJ 650
IBM Wheelwriter 15 won't get past lights coming on
Be sure the printwheel is proprly installed, Check the keyboard connectors and look for debris in the P/W area.
DickyO
Mar 28, 2009 | Lexmark Wheelwriter 15 Series II...
Four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Jan 04, 2009 | Cooktops
IBM wheelwriter 15 Series II not working
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
Dec 30, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
