Question about Kenmore 22422 Top Load Washer
Spin cycle wont ingage after it drains - Kenmore 22422 Top Load Washer
    President:
  • 1,776 Answers
The lid switch may be defective. If it is the machine won't spin. It located inside near the door frame and can be checked with an ohm meter. If bad, replace. Also check the condition of the belt. Hope this helped.
Posted on Jul 19, 2009
  • Kenmore Master
  • 8,220 Answers
Captain we have a problem. What is it spock? The H20 has been removed from the extractor but the main centrifuge will not remove the remaining liquid. The drive coupling has probably been compromised. Scotty get down there and check it out. Captain Im giving all shes got and she won't budge. McCoy fix it! **** jim i'm a doctor. Ohura send a message to earth: Mobilian get on it.
  • Kenmore Master
  • 1,606 Answers
Probable motor/trans coupling . If it agitates strongly but wont spin , then probable transmission problem . If not agitating also , then coupling problem .
I have a baumatic and its stopped spinning
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Spin cycle wont function wont drain
The pump is either clogged or burnt out. Check inside the pump hoses for a blockage first then try it again when cleared
Feb 13, 2010 | Whirlpool ET8CHEXSQ Dryer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Whirlpool washer, model CAM2742TQ0, direct drive. This is a commercial machine. It agitates and drains properly, but tub will not spin. I can hear the motor running and what sounds like the pump...
Sounds like you have a bad brake & Drive tube (spin tube) the brake may not be ingaging or the ear are broken off the tube ( you can check this just remove the agitaator and you can check the ears)
let me know if you find out ,,
Sep 20, 2008 | Whirlpool Washing Machines
Kenmore 22422 Top Load Washer Logo
153 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
