Question about Garden
Someone put oil only in fuel tank. Best way to clean it out? Now won't run smoothly with new fuel
  • Samuel Charles Spriggs May 11, 2010
    Am I correct that there is supposed to be oil in the fuel -- this is a 2 cycle leaf blower engine, correct? Did someone put too much oil in the gasoline, or only oil with no gas, or something else?
    Scholar:
  • 103 Answers
TRY TAKING OFF TANK AND FLUSHING WITH SIMPLE GREEN. CARB IS PROBABLY CLOGGED SO I DON'T KNOW IF CARB CLEANER CAN FLUSH OIL OUT. A REBUILD KIT IS ONLY 10-12 DOLLARS AND REALLY EASY. JUST DISSASSEMBLE CARB,PAY CLOSE ATTN AND BUY A CAN CARB CLEANER IN THE CAN AND FLUSH OUT EVERY HOLE IN CARB,WEAR SAFETY GLASSES AND DON'T TURN MIXTURE SCREWS. KIT COMERS WITH NEW GASKETS,BUY A PRIMER BULB WHEN YOU GET TO SMALL ENGINE SHOP OR OR GOOD LAWN MOWER SUPPLY SHOP. YOU WILL HAVE TO TAKE CARB THERE WITH YOU ALSO. I DID THREE ALREADY FOR BAD FUEL,REALLY EASY,JUST ATTN TO DETAIL. OH,REMOVED PLUG SPRAY OFF AND SCREUB OIL OFF AND GET A LIGHTER AND HEAT OFF GUNK OFF ELECTRODE. GOOD LUCK!
Posted on Jul 19, 2009
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
Idles ok revs up and stalls out
Aug 13, 2013 | Poulan Garden
Motor turns over won't start. Cleaned terminals, put in new battery, still won't start. Removed gas cap to vent air on hot day, still won't start. Lights all come on, all electrics appear to...
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 28, 2011 | 1997 Chevrolet Blazer
I have a Toro 4 cycle gas trimmer that won't stay running. Starts, then sputters, then dies. I've changed the oil, drained fuel & put in new fuel.
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Jun 30, 2011 | Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
