Question about Garden
Mss-SR Mitsubishi excavator moves and lifts lowers
M55-SR Mitsubishi excavator moves and lifts lowers backfill blade but no otter hydraulics. Think it is faulty boom sensor or the gadget that read depth of the bucket feeding info to computer I cant find any electrical diagrams that tell Me the part that will not allow electric hydraulics to work... any ideas
I think I can help you with it. Last year I had similar situation with my MM55-SR flashing red CPU light. The arm stopped moving, but the blade was working and I could drive as well.
I inspected all position sensors in the arm - each joint should have one. They look like small cylinders bolted to the joints of the arm with 3 wires coming out. In my case I had problem with the first sensor located by main (boom) piston where it is attached to the body of the machine. I removed this sensor from the arm with its wire. One wire was broke very close to the sensor housing. I was able to solder it and it solved my problem. Sometimes those wires can touch to the metal arm and rub off insulation causing electric shortage which also may stop the arm from moving. Check all connectors and wires for each position sensor first.
Hopefully this will help solving your problem.
If you want to share your experience you can email me at lferenc@hotmail.com
Posted on Aug 20, 2009
We may have a similar problem. Email me at ehenderson@minewise.net
Posted on Aug 07, 2009
Yanmar b15 excavator Boom and arm will not operate. everything else works fine. HELP.
Is there an interlock on the boom that wont allow it to operate if the front blade is not set? There could be an issue with hydraulic fluid, pump or PTO.
Feb 08, 2017 | Cars & Trucks
Cat E70B excavator
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
May 05, 2013 | Caterpillar E70B Excavator
My excavator hitachi ex200-1 weak swing and when you swing then stop vibration begin on turn table when i stop to swing,and when i swing and lift cylinder raise,vibration on the turn table will contin
Not sure would need to have a good look ,but i suspect a safety valve isnt closing properly causing thumping within the hydraulic system which is the vibration you can feel,shouldnt cost a lot to repair providing the faulty valve can be located so return to the dealer as they will have a good idea as yours isnt the first to go wrong iam sure
Sep 24, 2012 | Cars & Trucks
Warning light on in cab 235 c cat excavator
have you checked the level could be low or change the hydraulic filters they could be blocked. or it is just a service light.
Jun 13, 2012 | Cars & Trucks
New holland ls170 skidsteer runs but will not move and hydralics do not work
Could be very expensive to fix. Check that there is hydraulic fluid in reservoirs/pumps. Check seals on all hydraulics. Check hydraulic pump. Leaks? I'm not an expert, but I almost bought a used skidsteer for next to nothing, but consulted a local excavator-guy I know on it. He steered me away from it saying "It may only be priced at $3000, but it could cost you $10,000 to fix it.
May 27, 2012 | Toys
I have a lawn mower that has a hydraulic lift - and frequently it will not lift the mower deck or snowblower unless I push down on the lift assembly arm (it is connected to the mower by chains) while I...
Larry,
I have a Troy built x20 lawn tractor and the lift cylinder moves until the weight of the blade is on it and then it stops. Sounds like we have the same problem. Any luck with yours? ANy answers out there. Again, the cylinder will move raise and lower until the weight of the blade is applied. The left to right cylinder will move but very slowly. Any ideas from anyone would be appreciated.
Tim
Dec 17, 2010 | Garden
Garden Logo
627 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
