Question about Cyberhome CH-DVD 300 DVD Player
Door wont open to get dvd out - Cyberhome CH-DVD 300 DVD Player
Try to replace a worn out drive belt, most of these problems are related to this belt.
Posted on Oct 23, 2009
    Problem Solver:
  • 12 Answers
Shove it in ur ***
Posted on Jul 19, 2009
Door wont open
You may have a timing gear issue, broken loading belt, or stripped gears.
Mar 14, 2012 | Toshiba DR410 DVD Recorder
Drive door stuck and wont open
You can always try getting a jumbo paperclip, unbending it once, and inserting it into the small circular hole on the front of your drive. If your drive doesn't have the hole, then you'll have to probably take it to a repair shop.
Good Luck!
Jan 23, 2010 | Sony (DRU720A) DVD±RW Dual Layer...
Dvd player wont open
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Jan 03, 2010 | Panasonic DVD-RV26 DVD Player
My LITEON 5045GDL+ dvd drawer wont open.
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommend replacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
Jun 18, 2009 | Televison & Video
Tne dvd door will not open
These are instructions to open door if DVD is jammed or the DVD recorder wont open.
Unscrew the 7 cover screws and the 2 foot screws. Remover player cover.
Pry the front control cover off from the top of the player and not the bottom with a thin screw driver paying attention not to crack or break the tabs. Just lift them enough to clear the hooks.Then lower the cover withut removing it so you can gain access to the DVD front internal bezel.
On the left side of the DVD recorder there is a notch with a lever in it. gently push on it as this is the release for the DVD door. Remove DVD from tray and close.
Re-install all covers and screws. Machine should work after this.
Jan 17, 2009 | GoVideo VR2940 DVD Recorder/VCR
My dvd says open door will not open
You probably need a new dvd belt it is 24.25 mm rectangular. or it could've slipped off. Take off cover and move white wheel with teeth very gently until dvd tray starts to open then you can gently pull on it only pull it half way out and look in center of where dvd would normally be. There you will see the bigger and smaller wheels that control dvd player. look around for the belt. Make sure power is off when you do all this.
Dec 23, 2008 | Sony SLV-D350P DVD Player/VCR
Panasonic DMR-E85H - DVD door wont open
I opened the DVD door and something looked crooked... I pushed it down to straighten it... it clicked back into place and it works great! haha. I bought it off craigslist for only $15.. great deal. :)
Dec 06, 2008 | Panasonic DMR-E85H DVD Recorder
the door will not open at first it would open and close real quick, now it will not open and then it quits too, thanks jon
Jul 02, 2008 | Sanyo DWM-380 DVD Player
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Cyberhome CH-DVD 300 DVD Player Logo
166 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
