SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
SOURCE: Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
SOURCE: Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards,
Carlos
