Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 won't power on
There is power to the power supply, tested it to be sure, and there is a green light on the motherboard that turns on, but the cpu will not power on when the button is pushed. reset the ram, disconnected the cards, removed the battery, and still nothing. any thoughts? hoping for not a dying/dead mobo :)
  • 2 more comments
  • walshcode Nov 26, 2007
    I have the same probelm. The green light on the mother board is on, but the computer wont' power up.
  • Anonymous Mar 04, 2009
    I have the same problem. Please advice.
  • don6 Mar 14, 2009
    My problem is that even though the light is green, the computer tries to power on in short bursts. The front light will come on for a split second, the fans will spin for a second, and then it will do it again a couple seconds later. it goes like this until I unplug it. I have already changed the mobo and disconnected all the power hog devices inside.
  • don6 Mar 14, 2009
    Scholar:
  • 127 Answers
Might be a problem with the power button...try exchanging the power adapter and the reset adapter in your motherboard...this would become:
RESET BUTTON: as power button.
view your manual on where to find this adapters in your board.
Posted on Nov 19, 2007
I changed the power supply and problem resolved
Posted on Dec 09, 2007
I had the same problem with the same symptoms. Had it taken to a professional and found out it was in fact a faulty power supply. Good luck.
Posted on Dec 03, 2007
    Problem Solver:
  • 9 Answers
Before commencing, what color is the power light on the case? If it is flashing amber, you're looking at PS or MoBo Issues. If the light is off, power button. If the light is on green, then probably MoBo.
Posted on Dec 10, 2007
2 Suggested Answers
  • 565 Answers
SOURCE: Dell Dimension 5100 - CPU & Motherboard/System Temperature
u can also look rhe temperatures in bios under pc healt
Posted on Dec 26, 2008
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension 5100 will not turn on
Could be a bad motherboard? If your power supply was really fried it could have also fried your motherboard.
Mar 25, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 5100 won't come up after memory swap
Did you make sure that the power supply was off and or discontected from power source before opening the case?
It is possible that you have fried something by having a static discharge either from you hands or the vacume cleaner hose. Have you checked the correct installation of the memory make sure you are putting the original memory in dimm1 and dimm2.
Also check that the power button is still connected to the mother board just follow the wire from the back of the button just to be sure. Also check that the power switch on th power supply is on.
Link is to manual
http://support.dell.com/support/edocs/systems/dim5100/en/om/T8144bk2.pdf
Jan 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
1,127 people viewed this question
Alun Cox
