Question about Acer NSK8458AN Keyboard
ITS STUCK ON CAPS... HELPPPP!
MY KEYBOARD IS STUCK ON CAPS LOCK. I DONT KNOW WHAT I DID THOUGH. IF I KEEP MY FINGER ON SHIFT ONLY LETTERS ARE BACK TO NORMAL. I DONT WANNA KEEP MY FINGER ON SHIFT ALL THE TIME THOUGH HELP!
    Problem Solver:
  • 12 Answers
Haha stupid *** u broke ur keoyburd buy new 1
Posted on Jul 19, 2009
Sony Vaio keyboard repeating letters
Keyboards to wear out, but are not expensive to replace. Multiple key strikes and sticking can be caused by spilling "stuff" into the keyboard, even crumbs will do it.
Oct 29, 2015 | Sony VAIO Computers & Internet
Shift key not working
Well brother, It's a compatibility problem of hardware configuration with their respective software version.
I brought a Samsung RV509 Model in feb 2013 and after 2 or 3 months it's shift keys and caps lock stopped working.
This problem persist until now But, Now Shift keys and caps lock start working, Due to a Windows Update.
So, Keep updating your pc, This problem can be solved.
Mar 20, 2013 | Samsung RF511 15.6 inch Laptop - Black...
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
How i can unlock shift
If you are printing all CAPS then it is the Caps Locks key. It is located just above the shift key on the left side of the keyboard. There should also be a light on the laptop indicating the Caps lock is on.
Hope this helps
Jun 11, 2012 | HP Computers & Internet
Letters are all capital caps lock is off
you may have the Shift lock activated. keep pressing the shift key numerous times at a fast rate to bring p a prompt to deactivate it.
Failing that, you may have a stuck caps lock button (even if the led is off...yes it can still be stuck) so replace it
Oct 20, 2011 | Acer NSK8458AN Keyboard
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Wireless keyboard will not type numbers. Only the corresponding symbols will show up. The shift key is not down nor is it stuck down.
Although Shift key is not pressed down, maybe the electronics are messed up due to shock if you dropped the keyboard. Turn off Caps Lock, go to text editor of your choice and try to type numbers together with some letters. If you get big letters, then Shift button is pressed down.
In both cases, just to make sure, try your keyboard on some other computer and see if it works.
If you find out that Shift button is always pressed, than it is a hardware problem that may or may not be fixable.
Jan 15, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I dont know anything about cap locks i have to get a new password every time i log in to facebook and i dont know why they keep rejecting my password HELP
Caps lock is that key on the left side of your keyboard. When pressed, it makes all letters that are typed in into uppercase letters. For example; without caps lock pressed: "pressure". With caps lock pressed: "PRESSURE". If it mentions something about passwords being "case sensitive," this means that an uppercase letter A (A) is recognized differently than a lowercase letter A (a). Since you can't see your password being typed, it is important to make sure caps lock is not pressed. If this becomes too complicated, open up MS Word, notepad, or wordpad and type your password there so you can see it, then copy and paste the password into the password space on facebook. Good luck with that.
Nov 15, 2008 | Computers & Internet
Acer NSK8458AN Keyboard Logo
949 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
