Question about Watches
I need the movable ring on case front.It is like a diving watch with ring that has time markings on it around the crystal.
  • 65 Answers
Seek the services of a watchmaker. If it's a brand watch i.e. Seiko, Omega,Rolex etc. look for an authorised repairer they are far more likely to be able to source the part and fit it for you.
Posted on Jul 24, 2009
How do I use the moveable outer numbered ring on the t49825dh?
The numbered bezel can be used by divers to measure elapsed time on their oxygen supply. Place the zero where the minute hand is now and you'll know when 20 or 30 minutes have passed when the minute hand reaches bezel number 20 or 30.
In the same way, you can use the bezel to tell when 30 minutes have passed on your parking meter if you simply put the 0 on the minute hand when you leave the car. When the minute hand reaches the 30 mark, a half hour will have passed.
Typically, the bezel only turns counterclockwise to keep the wearer from bumping and changing the elapsed time number. On some less expensive watches, the numbered bezel does not turn and is decorative only.
Oct 23, 2014 | Timex Tiex en T49825DH Expedition Military...
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
The crystal of my wife's skagen watch popped out and the nylon ring surrounding the crystal seems too big to get back in, or perhaps I just don't have the right tools. Help!
Watch crystals are pressure fitted to their cases so that they are resistant to popping out. Think of a champagne cork, and how it expands when it comes out of its bottle.
Crystals are set into cases in one of several basic methods. First, a crystal may be installed from the back--watch cases are commonly assembled before the movement is installed. So, one potential way of reinstalling your crystal is to remove the watch movement from the case (if it isn't already) and try pushing the crystal from the back forwards. If this is indeed the way it was installed, the crystal should pop into position with a noticeable click or light thump to let you know that the other edge of the crystal has found the shallow groove in which it's supposed to sit.
Second, some crystals can be installed from the front using a tool called a "crystal lift." This tool has many little fingers that compress the edge of the watch crystal so that it can be slid into the case. Pressure is then gradually removed from the crystal, permitting it to expand into the shallow groove into which it's supposed to sit. Crystal lifts are easy to use in theory but somewhat finicky in real life; the crystal must be grabbed equally by all the lift prongs or else the crystal will have a tendency to squirt out of the tool before it's been completely set.
Looking at pictures of your wife's watch, it doesn't look to me like a crystal lift would do any good. I think instead that your crystal might have been installed using a third method. Looking at the pictures, it looks like the bezel--the metal top of the watch--separates from the watch body. If this is the case, gently pop off the bezel and push the crystal into it from behind. Then, push the bezel back onto the watch movement. It's possible that the crystal is kept in place by being squeezed between the bezel and the rest of the watch case.
If all of this sounds daunting, putting the crystal back in--assuming it's not cracked--is a minor job for a watch repair technician. It literally might only take 5-10 minutes to complete the job. If you're concerned about the appearance of the watch, it might be safest to pay someone the small amount of money to get this done right. Replacing a watch crystal with a new one usually runs about $15-25, around where I live. Replacing an undamaged crystal that's popped out should cost appreciably less, since a new crystal costs a jeweler between $5-25 for most standard sizes (diver's watches and strange specialty shapes will cost more).
May 16, 2011 | Skagen 358SSSD Wristwatch
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
Replace mineral crystal in Zodiac Sea Dragon ZO-2201
Its better you bring your watch to a service center ,Because equipped of all the tools.
Hope it may helps;
Jun 16, 2009 | Zodiac "Sea Dragon" Watch
Stem came out, question water resistance of watch now
Hi
The crown or winder, should have a very small o ring inside it, which seals on the watch case. Normally when replacing the stem this o ring would be replaced and lubricated with silicone grease to ensure water tightness. If this was not done there is no guarantee that it will still be waterproof (please dont forget to rate my answer, thanks)
May 04, 2009 | Navy Seal Luminox Dive Watch
Divers watch needs refurbished & repair.
http://service.movadogroup.com/pages.cfm?pid=4CD4575A-AB5B-AB72-9CDA4CE49DDD9176
This is a link to the Movado Group service centers, they make ESQ watches. It appears your watch has had water seep inside the case. It could be the seals around the caseback or crown. Whether repair is worth it, is up to you. I have had Casio dive watches I have sent into repair because I liked them, not for the value of the watch. In general ESQ makes a nice watch and if you like it, why not see what repair would cost. However, if this is a moisture problem, more than just visible corrosion has probably occured and the movement could compromised, if that is the case the costs of repair might outweigh just purchasing another watch. Good luck and I hope you found this helpful,
Apr 03, 2009 | ESQ Blackfin 300m Dive Watch Black Dial...
Need to replace crystal on Luminox 3000
All types of crystals are available worldwide.
Visit your nearest watchmaker and he will be able to supply new crystal and fit it.
Dec 04, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
Rotating outer ring
It is primarily cosmetic - the bezel was originally designed for diving, military activities or similar where counting down time was critical. Before digital stopwatches etc were built into watches as a feature, what you did as a diver was turn the bezel to the time (say 30 minutes) of air you had left, then the minute hand would travel around the face to the position 0 on the bezel, telling you 30 minutes had passed. You often find compass directions, various job specific calculators etc on bezels also, but unless you need a stopwatch / time reminder and don't have that feature in the watch itself, then it is purely a tradition to include a rotating bezel. The original bezels would have the time markings going the opposite way to the watch face usually, however on many modern watches, they often go the same way, allowing you to see how much time has passed, rather than how much you have left. Hope this clears things up :)
Mar 31, 2007 | Fossil CH2332 Wrist Watch
Watches Logo
56 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
