Question about Asrock P4V88 (P4V88 RAID) Motherboard
How can i install a 320GB sata II hd using Win XP without that jurassic 1.44 damned Disk ?
  • 2,567 Answers
You can slipstream the drivers from the floppy into an ISO image of the Windows XP installation CD using a program like nLite.
You can then burn the slipstream ISO image into a CD & use it to boot & install Windows XP without the need to use the floppy disk.
You can download nLite at the following link:
http://www.nliteos.com/download.html
After downloading the installer, install the program & start using it.
The following link describes how to use nLite to slipstraem the SATA drivers into the Windows XP installation CD.
I tried this myself, & it worked without problems. I now no longer need to use the floppy drive when installing Windows XP on my system.
Posted on Jul 19, 2009
  • Mohamed Omran Jul 19, 2009
    Sorry. I forgot to add the second link. Here you are:
    http://maxeasyguide.blogspot.com/2008/04...
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Can´t find my SATA-disk....
I'm sorry to say buddy but I checked ... Then checked some more, and I can't see anything about your motherboard supporting SATA-II. If you look about you should find a jumper setting on your HDD to limit it to SATA-I, which is about half the speed of sata-ii but I'm almost promising it will work.
Let me know if this solves it, If not I can find the jumper settings for you, But seeing as though you just bought it you should have a manual.
Apr 22, 2009 | MSI KM4M-V Motherboard
Can´t find SATA-disk on my motherboard MS-7061 and chipset KM400A
If the Bios does not see the disk, the operating system will not see the disk, nor will the install -even if you do an f6 to load drivers. It is most likely a problem between the motherboard not recognising the SATA-II interface. So no real solution I'm afraid. I suggest you install a SATA-II interface card which the BIOS will see, and add the card driver at f6 to install XP.
Apr 22, 2009 | Computers & Internet
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Presario Media Center new SATA 320GB WD
Check to make sure you used a SATA hdd & not a SATA II hdd for your replacement. Usually these are not backwards compatible. Hope this helps.
Jan 10, 2009 | Compaq Computers & Internet
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Cannot reinstall windows xp because I don't have the sata driver to load as we indows instll fresh copy
how are u my frind ?now l have acer desktop computer duel cor 1.8gh hard disk 160gband ram 1gb .sata hard disk and sata dvd writer.so now install win xp .how to connect hard disk and install win xp
Apr 19, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Asrock P4V88 (P4V88 RAID) Motherboard Logo
365 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
