Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Will not do anything but fill up and drain - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
  • 5,911 Answers
Check your lid switch. This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 19, 2009
How to change oil in standard trasnmission in Ford Ranger 1997
remove the fill plug before you do anything. If you can not remove the fill plug there is no reason to remove the drain plug since you will not be able to fill the transmission once the fluid is drained out.
Once the fill plug is out, remove the drain plug. Let oil drain into a drain pain. Reinstall the drain plug. Fill the transmission with the appropriate fluid until the fluid starts to drain from the fill hole. Reinstall the fill plug. Your good to go.
Jan 16, 2013 | 2004 Dodge Ram 3500 Truck
Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time
Jan 23, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
How do you put tramission fluid into the car - funnell??
There is a Fill Bolt on top of the transmission and a Drain bolt on the bottom of the transmission. Changing the fluid is simply a matter of taking the drain bolt off, letting it drain, putting the drain bolt back on and then filling it via the fill bolt. If you can't get the fill bolt off you will have to use the transmission dipstick tube to fill it which takes a while and requires some creativity. A drain and refill will probably take about 3 quarts of ATF. Make sure you buy the Honda Z1 ATF from a dealer because in my experience honda transmission just don't work right with anything else.
To see the complete guide, please click the link below:--- http://technoanswers.blogspot.com/2011/04/how-to-fill-transmission-fluid-in-2006.html --------------- This should help.Thanks.Helpmech.
Apr 26, 2011 | 2006 Honda Accord
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Dishwasher will fill and drain, but will not cycle!
Bobalou If you just bought and installed, I'm assuming you dish washer is brand new. It means it has full warranty with Maytag. Do not do anything. It will void your warranty. Call Maytag authorized service. Gendos...post back
Jan 23, 2007 | Maytag 24 in. MDBH750AWS Stainless Steel...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De
