Question about Garden
Only two months old...stopped running,as tho it ran out of gas but it did not...getting spark but doesn't even pretend to start.
  • ecaldwellcla Jul 26, 2009
    fuel lines fine...tried both gas and starting fluid jn spark plug hole with no luck...plug has spark which seems a little weak to me and is wet with fuel. Took carb off and cleaned it out with no luck. HELP!!!
  • 127 Answers
Look in the tank and make sure fuel hose did not fall off, also pour a little fuel directly in the sparkplug hole and try starting let me know what happens
Posted on Jul 26, 2009
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Start and ran the mower for 10 min Shut it down and now can't get it running for more than 10 sec. Changed the gas drain the old gas Changed the spark plug, cleaned the filter as stated. still can
Tecumseh engine right? Pull the float bowl off the carb. I suspect some water contamination. while it is off clean the jet holes in the nut. They may have varnisized gas in them. contact me with any more questions.
Sep 13, 2012 | Yard Machines Garden
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
Im trying to get this 92 isuzu rodeo v6 3.1 4x4 (with 130,000 miles)going for my son.about 4 months ago we jumped started it(bad battery) and we took it to the gas station and put about 6-10gal of fresh...
wow no tuneup this decade
ever heard of new spark plugs first.?
$1.49 each find a sale., hint hint
fitlers, sure. both. air and fuel.
check compression? if way low
cam belt slipped.
that to is a 60,000 mile tune up part
why not read the list in the operators guide, or buy one
same with old spark wires, get new mag wires set from NGK
Feb 28, 2017 | 1992 Isuzu Rodeo
My bass boat sat for about 8 months. I had it on the water this weekend and it was not idling well and had trouble starting. Once started, the boat ran well when i was in the throttle. I ran the old gas...
SOUNDS LIKE THE CARB LOW SPEED JETS ARE CLOGGED , THANKS TO THIS PITIFUL GAS WE GET TODAY ,I USE A ADDITIVE CALLED SEA FOAM IT WORKS GREAT JUST ADD TO FUEL EVEN WORKS FOR WINTER SET UP TOO
HOPE THIS HELPS
Aug 10, 2010 | Light Outboard Motor Boat Bass Fishing...
My back pack ran good for 2 seasons. I have not used it for probaly 6 months this time. I tried to carnk it with the gas that was in it and it would fire but not keep running. I emptied the old gas out and...
Ron--It sounds to me as tho the crankcase and cylinder is loaded with gas. Try pulling the plug out and cranking the blower over many times to try and try out the cylinder. When that's done, put the plug back in, connect the plug wire, hold throttle wide open, NO CHOKE, and pull it. It should eventually fire. May have to do that several times to get the old gas sucked out of the crankcase. You may very well have a gummed up carb, but that can be addressed later.
Oct 25, 2009 | Ryobi Backpack Blower 25.4cc
Bad running craftsman 25cc trimmer 4 yrs old
You need to do a couple of things to get your trimmer back on track. First of all pour out the old gasoline and get rid of it. Then remove the spark plug and go to an auto parts store and get a new one just like the old. If you have your manual, check to see what the recommended spark plug gap is gap it to that specification.
Finally remove the air filter and clean it or replace it as necessary.
Once that is all done, but some new, fresh gasoline. Then put in the new plug and the new gas and u will be good to go. please rate this answer as a FixYa cause it is.
Feb 25, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
