SOURCE: Suzuki S50 electrical issue
I had the same problem with mine. It would usually work to just jump down on the seat and everything would come back on. Then one day it wouldn't work. I eventually narrowed it down to the battery connections. The bolts to the battery seemed tight when checked through the access holes on either side of the bike. I removed them and dropped the battery down to find the small bar in the battery post was loose from the front side of the battery. I tightened both of those bolts, put the battery back in and re-connected the wires to the side of the terminals. That was almost 2 months ago and it hasn't happened again yet. If they do come loose again, I'll put some loc-tite on them next time.
SOURCE: front wheel torque specs 2008 S50 Suzuki Boulevard, main wheel bolt, safety nut & caliper bolt
40 foot pounds.
Testimonial: "thanks!"
I'm sorry that was misspelled. It pops and backfires. And sputters And then it will eventually die and can only be restarted with choke pulled all the way out.
