Question about Hayward H Series
Heater shakes when running - Hayward H Series
  • j_asa Jul 19, 2009
    loud banging or loud clicking
  • 27 Answers
Inside the heat exchanger is a governor valve like a car thermostat and a bypass valve that controls the temperature of the water in it by adjusting the amount of new colder water and heated water circulate in it.. When these don't operate properly they cause your problem get a certified rep to fix.
Posted on Jul 20, 2009
My all-pro uk115t shuts off after a few seconds
This is normally due to either a clogged intake filter, or water in the fuel. To rinse the intake filter and the tank, put in a quart of fuel and shake, shake, shake to rinse crud off filter and dump out. Otherwise you'll have to disassemble to get to the filter. To remove water from fuel, dump it into a bucket. The water will coalesce in the bottom, then pour slowly back into the tank, leaving the 'bubble' of water in the bucket.
Feb 18, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
My 175000 heater runs for a little while then shuts off, if I shake it back a forth then turn it back on it will run a little while then shut down again.
Your heater may be equipped with a switch that turns it off if knocked over or tipped. The switch may be defective.
Oct 17, 2014 | Heating & Cooling
Pentair minimax heater works but why is it making a chugging sound?
sounds like you have air in the system u will need to bleed it out while the pump is running.
May 23, 2014 | Pentair Minimax NT Heater
My Pentair Mastertemp shakes and rattles, then cuts off after about 15-30 seconds of running. I called a pool co. and they told me to replace the water regulator valve, which I did. The same problem is...
When a heater starts rattling and shaking it has nothing to do with the water regulator. Some of the most common possibilities are as follows:
1. Very low water flow. If the skimmer or strainer basket on the pump or pool are clogged, or the filter is dirty, or the pump is old and not working properly, you can get just enough flow to activate the heater, but not have enough flow to do it safely. When there is too low of water flow, the water inside the heat exchanger evaporates into steam which creates pressure inside the exchanger which cannot be released, therefore making the heater "jump" or "shake" al over the place. This fix is easy if this is the case, fix the flow problem.
2. Hole in the heat exchanger. When heat exchangers start to fail, they get small holes in them letting air into the system. When this air gets super heated it expands and creates pressure just like the above situation (kinda). This will also create the shaking.
3. Completely clogged heat exchanger (inside the exchanger). If you fill off a well system, or have high metals and minerals in your water, these metals and minerals will attatch themselves to the inside of the heat exchanger thus clogging it and reducing the water flow through the heater to just about nothing. There are 3 cleanout plugs on the heat exchanger so that it can be regularly flushed. This should be done at least once a year.
4. Clogged heat exhcanger (outside the exchanger) This is the least likely, but if you are getting a bad burn on the heater due to not getting annual services, the heater will soot up, prohibiting the natural venting capabilities of the heater, and trapping ALL of the flames heat on the exchangers bottom. With nowhere to go , once again, the exchanger is super heater and pressure builds up enough to shake rattle the heater.
Sorry there are so many options for this, but all signs point to this heater needing a serious cleaning inside and out. It can be done by you, but should probably be done by a service tech.
If you have more questions, contact me @: adamh@newconceptchem.com
Jan 21, 2011 | Pentair 460730 MasterTemp Heater 200BTU ...
My Hayward H model makes a heavy clicking noise while running. In fact, it will shake the entire unit. It only does it after egniting.
Check to be sure your heater by-pass is closed off. If not the water inside will overheat and shake and bang inside the heater.
Jun 26, 2010 | Hayward H-series Electronic Gas Pool...
Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Sep 06, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 starts then turns off or shake/bangs off w/error HL1
the heater is plump correctly?if yes assembly valve need replacement, if you by pass before dirt may be inside.
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Logo
155 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
