Question about Bissell CleanView II Plus Upright Bagless VacuumVacuum
Sucking up but nothing appears in the canister
  • 97 Answers
You have a clog somewhere
Posted on Jul 19, 2009
Head not spinning and sucking up
You share a common misconception. There is nothing to spin except the dust in the canister. All plastic parts are static. If you've cleaned the filters as instructed in the manual (download from Dyson website if you're unsure and have lost the original), the most likely problem is that you have a blockage in the pipework. You need to separate the hose and wand, and remove the hose from the machine, and check all through - you will almost certainly find something that shouldn't be there!
Good luck.
Jun 23, 2010 | Dyson DC05 Bagless Canister Cyclonic...
My canister kenmore progressive is not sucking and is sptitting carpet powder dust all over the place. could it be it needs a new hpa filter? if so where on the vacuum would it be located?
Remove the hose from the canister, and turn on the vacuum. Does it produce good air flow into the hose port?. If ok, remove the hose from the sweeper unit and plug the end into the canister. If ok, check the bottom of the sweeper head for plugging of the air passages and inspect the sweeper bar for accumulation of thread, hair, and string. If the first test produced no air flow, then open the canister and remove the bag--turn the vacuum on and check for air flow into the motor. If still nothing, then check the hepa filter which should be near the air output from the canister. Go to: searspartsdirect.com and enter the sears model number from the information plate. The machine's part drawings will appear and select the vacuum case drawing which should display the hepa filter location and also be able to order the filter from the web site. Hope this helps!
Mar 13, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Motor starts but shuts down Brushes not turning no obstructions on brushes
was sucking up some powder and after cleaner was emptied and had a rest it appears to be operating again. thank you
Jan 30, 2010 | Dyson DC05 Cylinder Bagless Canister...
My henry hoover has stopped sucking
screw the pipe off and clean with cold water.
check dust bag or change,
check that nothing is abstructing the suckstion from the head & neck. of your hover,
Oct 29, 2009 | Numatic Henry Bagged Canister Vacuum
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Not sucking up water
Hi.  I had the same problem.  After looking at the manual I went back and made sure the canister was making a proper seal.  That fixed the problem.  Make sure when you put the top back on the canister (that holds the dirty water), that you place the two front hinges in  place first and then snap the center clap on the back of the top.  This will give you a proper seal for suction. (My two front hinges weren't fitting correctly.)
Oct 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Bissell CleanView II Plus Upright Bagless VacuumVacuum Logo
91 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
