Question about Denon AVR-1508 Receiver
POWER TURNS OF AFTER IT WAS TURN ON - Denon AVR-1508 Receiver
Tip
HP Office Jet All in One : Resetting Steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
on Jan 19, 2010 | Office Equipment & Supplies
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
Amp turns off
Sounds like remote turn on wire is bad. If using aftermarket HU, find another location to power amp. Try the the power antenna wire on the HU to run the REM.
Jan 24, 2009 | Pyle PLAM1200 2-Channel Car Amp
TV turns itself off
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 08, 2008 | Akai LCT3201TD 32 in. LCD Television
My panasonic pt-51hx41e will turn on for couple secs then turn off
hello. it sound like a power supply problem.!!! to me .!!! you can check it frist.!!!"good luck"
Aug 01, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Denon AVR-1508 Receiver Logo
183 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
