Wen its idling the revs jump up and down and have to rev it hard wen I start it I have to rev it hard or it stalls it idle at 1500 rpm and then jumps to between 2000 and 2500 rpm
SOURCE: 2004 stratus 2.7L Erratic idle, sometimes dies, sometimes revs at stops
hey-I have has this before different car but same - idle control valve is failing - computer at shop will pick this up on diagnostic
SOURCE: At idle the engine revs up and down
engine lite on? would ck to make sure there is plenty of coolant in system. low coolant may cause idle hunting. also could have a vacuum leak or air intake restriction. ck air filter
SOURCE: high revs
being a fuel injected engine , there are many reasons this could be happening.
from the top , lets check the Manifold Absolute Pressure (M.A.P.) sensor , as it is easiest.
Find the MAP sensor , it has a couple a wires and a vacuum tube going to it and is on the firewall or fender support under the bonnet.
Disconnect the wire harness from it (small plug with wires).
If the engines RPMs drop to normal , replace the MAP sensor.
SOURCE: Idle jumping up and down
MAKE SURE WHEN YOU PLUGGED THE SPARK PLUGS IN THAT YOU GOT THEM IN THE RIGHT FIREING ORDER,ALSO MAKE SURE THAT YOUR THROTTLE BODY IS OPERATING NORMALY WATCH IT WHILE THE CAR IS RUNNING TRY MOVING THE THROTTLE BODY ROD BY HAND
SOURCE: idle irratic
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
