Question about Tricity Bendix AW1054 Front Load Washer
How does this machine work??
I"m using someone's machine, it's a Bendix 1054 front loader. It's got weird settings I'm not used to, goes forever, will stay locked for ages. please HELP.
  • chassg Apr 20, 2008
    yes have the same problem it takes 3 min to open safty switch and will only stop at end of cycle and then open
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
chassg,
It is normal for the door to release after 2 or 3 minutes, its a precaution set by the machine; do not force the door. And surely the cycle must end for you to have a nicely washed clothes. Don't try to stop front loaders inbetween, less probs for you.
Posted on Jun 16, 2008
Bendix wd-1054 bx
Get a manual from a dealer or on a product website
Oct 12, 2014 | Washing Machines
Can i get a manual for bendix wd-1054 bx washing machine?
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 27, 2011 | Tricity Bendix AW1000W Front Load Washer
I have a wdr1242 washer dryer the dryer seems to take forever to dry clothes sometimes 2 hours or more even for just half a dozen socks
If your dryer is still heating up; Check the dryer vent hose, also check down inside where the lint screen goes. If no lint is obstructing there, check the exterior dryer vent. Sometimes you have a screen to keep birds and rodents out of there, and may become clogged with lint. If no screen, check inside the flap, maybe someone moved in, or dryer lint is clogging up your exterior vent.
Dec 08, 2010 | Tricity Bendix WDR1040W Front Load Washer...
What is the quickest wash cycle for the tricity bendix wdr1040w front loader
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Hope this was helpful.
Good Luck
May 04, 2010 | Tricity Bendix WDR1040W Front Load Washer...
My ftf530fs has worked every time I've used it, but tonight when I closed the door it would not start. The door lock light is on, but it will not start on any setting. What do I need to do?
My GE front loader did this. I unplugged/plugged it in and it started. Weird, but I hope your solution is that simple. Also, check your breaker.
Nov 15, 2009 | Frigidaire FTF530FS Front Load Washer
Drum is really loose and when hits spin cycle makes loud noise
Most front loaders are pretty much the same and it sounds like your tub bearings are going bad. There is also a problem in some front loaders where the drum arms corrode and break. You won't know until you pull it apart. If you are doing the work yourself it depends on the parts you need. You can knock out old bearings and match some up.
If you are paying someone, it may be cheaper to buy a new washer..
Jan 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Bendix washer dryer 1054
the brushes need replaced in the motor by the sound of it
Feb 24, 2008 | Tricity Bendix AW1000W Front Load Washer
Bendix L 105 RX
you can get it here
http://www.serviceforce.co.uk/pdf_search1.asp
you will need to enter the model nu like this L105 RX
it took a while to find
Feb 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Bendix WD 1054 R Front loader fails to pump out water sometimes
Pretty sure that the pump is the problem here. Could be something that blocks the pump, or the pump is just bad.
Jan 28, 2008 | Washing Machines
Tricity Bendix AW1054 Front Load Washer Logo
174 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
