Question about Garden
No spark Tecumseh FC420v Electronic Module bad?
Fly wheel does generate a tingle if I turn the magnet by the coil. measured resistance on the high voltage lead to chassis ground and resistance from low voltage? lead to chassis ground. No resistance measured on the input to the Electronic Module. The low voltage wire goes into the module then into the rats nest wiring harness... I suspect this is a kill if bridged to ground.
I suspect the Electronic Ignition module but have not ruled out wiring, as I do not have a diagram.
There is a white wire off the coil that goes into the postage stamp sized module. There is also a red wire wrapped aroung the spark wire... is this the trigger for the module?
If no spark, does it sound like a bad module? Is there a such thing as a generic one, or do I need an OEM replacement? How much should one be and where does one find one on a Sunday?
Thanks, in advance.
  • Lake Dude Jul 19, 2009
    Sorry, it is a Kawasaki. My bad.
  • 155 Answers
Hi theres not much you can do with these modules the only place you can get a non genuine one is a company called stens they sell a lot of spares for power equipment.
Hope This helps.
Posted on Jul 25, 2009
Can I test an ignition module on an onan engine with a volt, ohm or amp meter?
well sure you can, allthough if you have allready replaced the coil and plug , i can't see why you'd need to , it's the last thing there is to replace , but if youd like to anyway , just ground the black lead of volt meter anywhere on engine thats not painted or rusty , hold red lead on - side of coil (its the one with half the battery voltage on it) and turn engine over slow as possible you should see the volts rise and fall as it turns over , if not the ign module is not working
also i question why does this have a condenser if it has electronic ign ? cant say id ever seen that before .
Sep 24, 2014 | Cars & Trucks
Mastercraft tiller manual
Did you really crack the shaft trying to remove the inertia or fly wheel
May 20, 2014 | HP Tools & Hardware - Others
My husky1850 generator has no spark used once, 1yr old.,
Hi ikeano29...
Remove (if necessary) and check your flywheel where the magnet is at for rust,corrosion, and lightly sand with fine sandpaper to clean the surface, then sand the face of the induction/ignition module to also give it a good conductive surface.
Reinstall the flywheel again, if still no spark...then replace the induction/ignition module as it is faulty.
Note: Be sure to measure the distance between the module and the flywheel to make sure you put the new module in at the correct distance from the fly wheel or you will get no spark also.
Please take time to rate me
Aug 29, 2011 | Garden
How to tell which of the 8 coils on a 1998 Pontiac trans-am ws-6 is bad?
This may help in some cases... At night turn all the lights off, wait a bit for your eyes to ajust to darkness, start the engine and look at your coils. Bad one will have a blue sparking inside. This solution does not work in all the cases though. But it is fast and easy. If you can't find a bad one like this then try to measure resistance of the primary for each coil because it could be a burned primary.
Mar 14, 2011 | Pontiac Firebird Cars & Trucks
How do i refit a ignition coil tto get the park how close to the fly wheel does it have to be because i can notget any spark at the moment.
Turn the flywheel magnets under the module poles and insert a thin business card into the pole gaps. Loosen the module screws and allow the module to contact the magnets. Tighten the screws then rotate the flywheel somewhat to release the card. Remove the stop switch wire from the end of the module body, then try for spark. If still nothing (You have tried a fresh spark plug gapped at 0.020"), then replace the defective module. Hope this helps!
Jan 31, 2011 | Garden
It's about Husqvarna 345 chainsaw. I would like to know the resistance value between spark plug wire and blue wire from ignition coil, and between spark plug wire and the ground and finally resistance...
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Nov 21, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Have 10 hp Tecumsa engine and can not get ignition spark from plug. Have new spark plug, cleaned flywheel & coil with emery cloth. Have checked on/off switch for continuity. Can ignition coil be tested...
Did you check, that the magnet is on the flywheel.
When you cleaned the flywheel, did some metal rasping gather around it.
The magnet should be strong. A small steel instrument will be pulled by it.
The high voltage coil can be tested for resistance with an Ohm meter. The resistance may be some kOhm but not MOhm. If MOhm it should be replaced.
If the coil and magnet are OK, and well attached to the flywheel and aside with a minimal air gap, then the coil may be checked by turning the flywheel. As the voltage on coil ends when magnet passes by the coil should be very high, the only way for checking is with a spark plug, connected to the checked high voltage cable, the thread of the plug well connected to motor case. A spark is the prove that it is OK
Check also the HV cabel and the connection of other coil end to motor case.
I hope that this will be helpful, because I don't have your device in front of me. Some people rank such an answer with 2 thumbs (meaning useless). Better don’t rank.
Jul 28, 2010 | Coleman Powermate Premium Plus 6250W...
Husqvarna ST927 With Tecumseh hp engine has no Spark
there are a few different reasons(faults) why there wouldn't be a spark one is an open in the spark plug wire that would result in a very weak spark or a short to ground or a short to ground due to chaffed or broken insulation the third and least likely and more expensive reason is a bad magneto the mag is just a bunch of coiled wire that is bolted to the case or frame next to the fly wheel and a magnet mounted on the fly wheel passes by the coil and this makes the spark if the magnet or induction coil is damaged or broken off there wont be a spark ....start with the spark wire trace it back to the source (coil) and make sure it isnt damaged an omh meter will help to determine continuity and a megger will be be able to determine if the insulation is broken down and just not visible though there will most likely be visible damage if there is no spark at all..... also you could try starting the engine while listening for a snap somewhere other than the spark plug...good luck
Dec 21, 2009 | Husqvarna Garden
1998 jeep cheeroke starter problem
Yes I believe that would fix the problem. It is under the hood mounted in the "power distribution box"
If this by slight chance doesn't work which I do think will work; Then you can try
The HEI system, used on 2.5L, 2.8L and 4.0L engines, is a pulse-triggered, transistorized controlled, inductive discharge ignition system. The entire HEI system (except for the ignition coil on fuel injected engines) is contained within the distributor cap.
The distributor, in addition to housing the mechanical and vacuum advance mechanisms, contains the electronic control module, and the magnetic triggering device. The magnetic pick-up assembly contains a permanent magnet, a pole piece with internal teeth, and a pick-up coil (not to be confused with the ignition coil).
In the HEI system, as in other electronic ignition systems, the breaker points have been replaced with an electronic switch-a transistor-which is located within the control module. This switching transistor performs the same function the points did in an conventional ignition system. It simply turns coil primary current on and off at the correct time. Essentially then, electronic and conventional ignition systems operate on the same principle.
The module which houses the switching transistor is controlled (turned on and off) by a magnetically generated impulse induced in the pick-up coil. When the teeth of the rotating timer align with the teeth of the pole piece, the induced voltage in the pick-up coil signals the electronic module to open the coil primary circuit. The primary current then decreases, and a high voltage is induced in the ignition coil secondary windings which is then directed through the rotor and high voltage leads (spark plug wires) to fire the spark plugs.
In essence then, the pick-up coil modu
Jan 20, 2009 | 1998 Jeep Cherokee
Tecumseh oh 140 solid state module
Check that the gap between the flywheel magnet and the module is correct, take the kill wire off the module, hook up a spark tester to the output of the module (spark plug removed), spin the flywheel - No spark means that the module is bad.
Rank this answer please,
Carl
Oct 23, 2008 | Welding Tools
Garden Logo
412 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
