Question about Dell Dimension 8300 PC Desktop
Help, I open the case on my Dell Dimension 8300 to gently blow the dust out (hand held bellows). When I closed it and rebooted I get a message saying 'can't find the primary drive'. The drive is IEE. I didn't touch anything inside the box so I am stumped. the keyboard is unresponsive. Help appreciated.
  • 1 more comment
  • Peter Sullivan Jul 19, 2009
    Thanks. I knew compressed air was an issue, but was ignorant about the bellows.
    I can hear a faint hum from the case, but can't tell if this is the power supply or the drive. What I did notice when I opened the case was how kinked the cables were, but I didn't touch any of this. I worked on a wooden bench and a wooden floor.
    I will open the case again and check the connections.
    Thanks, I appreciate your input.
    Thank you both for your help.
    I reopened the case and pushed firmly on the drive cable. When I rebooted the Windows screen reappeared and my keyboard is recognised. Maybe I should replace the cable. Thanks again. Lesson learned. Phew!
    Thanks everyone. problem resolved (for now).
    President:
  • 2,976 Answers
Just check ALL connections. When you do ANYTHING inside a computer, you should wear a grounding strap, available at places like Radio Shack for a few bucks. Compressed air DOES create static when coming out of the can, although, it isn't usually enough to do any damage.
Posted on Jul 19, 2009
  • 33 Answers
When you turn on your pc press the DEL key or the F1 key for your BIO setup. Select standard use the down key and select the ide harddrive than press the ENTER key. the screen will display hdd spec's. If not, check your hdd connection inside the case and the keyboard connection as well that the back of the case.
  • Dell Master
  • 3,866 Answers
You suppoed to use a can of compressed treated air as this could have done some damage.
1. Check the primary drive cable make sure it did not come un-loose?
2 is the drive spinning up
You might have damaged the system it would be hard to tell and yes anything but treated air that is not recommended for computer nor eletonics can carry static eletricy and can kill compnets.
thanks
The dell dimension 8300 is run in high end then low
This indicates that the Processor is getting too hot. When the Processor gets hot the computer is programed to increase fan speed to cool itself down. To solve this problem you will want to install a chassis fan in your computer's chassis, either bringing freash air into system (intake) or as an exhaust blowing air out of your computer system. Purchase them at your local computer store they are inexpensive and are a great asset to your computer system.
Another option that will help the most is to clean the processor fan of dust. Dust accumulates over the heatsink and prevents the cool air from cooling your processor. Remove the dust with a vaccum cleaner and a paint brush. Do it in a very gental manner as you don't want to damage the fan blades. In some cases it is possible to remove the fan and get at the dust that way.
Take care!
damnor01
Sep 07, 2010 | Dell (6F858) Cooling Fan
Can't open dell dimension 3000 to add memory
A tool-free side panel slides open easily to reveal a roomy interior with two free PCI slots. ... The Dell Dimension 3000 is an affordable computer designed to handle essential multimedia demands for the home user. The Dimension 3000 comes with the latest processor and memory technology, and won't break your budget.
May 14, 2010 | Dell Dimension 8300 PC Desktop
My dell dimension 8300 is displaying the error message " System battery voltage is low". What is the battery like? Where do I get it and how do I change? Please help
This message is likely referring to the battery used to hold your BIOS settings.
If you open your computer case, you should see a coin-shaped battery on the mother board. This is the system battery.
See this link for more detailed instructions.
http://support.dell.com/support/edocs/systems/dim8300/sm/battery.htm
Nov 17, 2009 | Dell Dimension 4600 PC Desktop
UNPLUGED
Ribbons you should have 2 one for the cd rom drives and one for the harddrives, Look closley on the borad and it will say next to the connector which is which, the ata one will go to the harddrive and the ide one will go to the cd rom drive the end that only has one connector goes into the borad, the one with 2 connectors kinda close goes into the compoents, DO you have more than one hd if so you may need to find out which one is the master and which is the slave!
Nov 17, 2009 | Dell Dimension 8300 PC Desktop
How do I open a Dell Dimension 8300. I lost my manual
There are two release buttons, one is on the bottom of the case and one on the top. Lay the case on its side and depress these two buttons and the case opens like a **** shell. There are slide hinges attached to allow it tp open wide without disturbing the wiring looms inside.
Aug 31, 2009 | Dell Dimension 8300 PC Desktop
How do I remove the fan shroud from a dell dimension 8300?
there are two clips one on the top and one at the bottom u have to press both the clips and open the shroud.
Jun 07, 2009 | Dell Dimension 8300 PC Desktop
How to remove tower cover...
Hi, Please find the instructions for opening the 8300's cover. http://support.dell.com/support/edocs/systems/dim8300/sm/cvrop.htm I hope this helps. If it does, please don't forget to rate the solution.
Mar 20, 2009 | Dell Dimension 8300 PC Desktop
Changing the clock battery on a computer.
This should be a very simple process.
Just open the case, their should be a button on the top rear and bottom rear of the case, press both and case will split open.
Picture below of battery removal:
Diagram may not be exact, but you should be able to pop this out with your fingers or a small flathead screwdriver
Mar 15, 2009 | Dell Dimension 8300 PC Desktop
Computer has shut down and can not re-start
The Dell 8300 does not use industry standard parts. You need Dell specific parts in order to replace the fan. Here is a link to a replacement fan shroud assembly for your Dimension: http://www.discountelectronics.com/index.php?l=product_detail&p=845
You may be able to find cheaper if you do a Goggle search and dig deeper. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 PC Desktop Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
