How to remove and replace the fuel filter in 1996 mitsubish lancer
SOURCE: location of fuel filter for 2005 Mitsubishi Lancer 1.8 litre
a guess... fuel filter should be up against subframe behind rear wheel in front of fuel tank...follow fuel lines down frame rail from motor to back end to find it.... good luck
SOURCE: removal of fuel filter
The filter is located under the truck on the driver side... You have to go to a auto parts store and buy a fuel filter key for that year!!
SOURCE: removing air from fuel lines after replacing filter
it is self bleeding, just crank it for about 10-20 seconds.
SOURCE: 2003 mitsubishi lancer es fuel filter
it's in the fuel tank, you really don't have to replace it unless you have problem with fuel pump.
to acess the fuel pump you need to take the rear seat off
SOURCE: where is the fuel filter
its in the tank with the pump you will have to drop the tank or i found out it was easier to remove the bed or just lossen the bolts and lift up the side where the tank is.
