Question about Radio Shack Pro-94 Scanner
I have two frequencies that I want to listen to simultaneously, is this possible. Also I want to be able to turn on the scanner and it be right on that setting/channels.
3 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Pro-97, only want to listen to EMS
Not being completely familar with the radio system you use... i would presume that your dispatch uses a subaudio tone to "turn off" the squelch on the radio you use as an emt.... if you know that tone make sure it is turned on for the scanner on the frequency that you are using. i presume the id numbers are specific to areas of the city.
Robert
Posted on Sep 12, 2008
  • 120 Answers
SOURCE: the frequencies on my scanner are not coming in
while the weather channel is coming in hi LO (lockout) so that if its programmed into a regular scanning memory it will skip. If that dont work look for a lock button or keyboard lock and press that then scan.
Posted on Mar 07, 2009
Where can I find a free owners manual for a Uniden Bearcat BC 177 XLT EMS fire police scanner radio
All these cat scanners work pretty mich the same
There are several ways. First, turn the scanner on and adjust the squelch so that it is quite. Then press the manual button to flip through the 16 channels. Stop on the channel you want to program. Then, type in the frequency followed by the "E" key on the lower right of the keypad. Hit the manual button to move to the next channel and repeat the process above.
You can also "scan" for a frequency. Here is how: Use the manual button to get to one of the channels. Now type in "120.0 followed by pressing the "limit" button. Now type in "125.0" and press the "limit" button again. Now press the "scan" button. The scanner will now search all frequencies between 120.0 and 125.0 on that channel and will pause and listen should a transmission happen. You can do this "limit" scan for any frequency range that the scanner is capable of receiving. Once you hear a transmission, you can press the "hold" button to stay on that received frequency. Pressing the "E" button will lock that frequency into that channel.
Nov 15, 2014 | Uniden Radio Communications
Clear the memory of a Uniden BC346XT
Turn off the scanner.
Simultaneously press 2, 9, and HOLD.
While continuing to press these buttons, turn on the scanner.
If you need a manual, you may view it here.
Mar 12, 2012 | Uniden BC346XT Handheld Scanner
My scanner no longer scans the local police and sheriff frequencies. It will only scan the next county sheriff frequencies. It was originally programmed to scan Omaha police and Douglas Co. sheriff.
It's possible that your county services have switched to a trunking system, leaving you with nothing but "dead" frequencies. To check the frequencies and systems that are currently in use in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
May 29, 2011 | Radio Shack Pro-97 Handheld Scanner
Can you listen to a police frequency if it's trunked with this scanner? Uniden BC72xlt
You can listen to trunked police bands UNLESS: 1 they went Digital and your scanner is Analog. 2. They use an encrypted control frequency. 3. It is not against the law in your area. 4. you have a Trunked scanner. Following trunked frequencies requires a trunked scanner which is very different from regular everyday scanners. If the photo of your scanner is accurate then it appears you have Digital capability so that won't be a problem. You can go to Radio shack and purchase a book on Public Safety frequencies and Control Frequencies which will give you the proper frequency range but they will tell you nothing about Encryption on any Frequency. If you can not find a Control Frequency then you will not be able to track the hoping that is used in a trunked system. By the way, a Regular scanner runs about $50 where as a Trunked Scanner runs $150 to $200.
Oct 16, 2010 | Uniden BC72XLT Handheld Scanner
C an i open lock uniden scaner?any idia?i want to recive all frequineces
A modern scanner is only capable of receiving the frequencies listed in the operating manual. There is no magic spell that will "unlock" your scanner. If you want to cover more frequencies, you'll need to purchase a scanner that's capable of doing so right out of the box.
Bill B
Sep 29, 2010 | Uniden BC248CLT Base Scanner
New BC355C put 7 channels in,but only will stop on 2
1. Be sure sure that your squelch is adjusted properly. While scanning, turn the SQUELCH control down slowly until scanning stops and you hear a hissing sound. Then slowly turn the control back up until scanning resumes. That will set a proper threshold level for the frequencies you're monitoring.
2. Be sure that signals are not blocked in your area. Topography plays a large part in VHF and UHF radio reception. A hill, a tall building, even a thick grove of trees can prevent a signal from reaching your antenna.
3. It's possible that there was just no traffic on the five freqs while you were listening.
4. Be sure that the frequencies you've programmed are assigned in your area.
5. For a comprehensive database of active frequencies in your area, visit:
BillB
Jan 26, 2010 | Uniden BC350C Base Scanner
Do all 20 channels scann at the same time? S1&S2
I'm not sure which specific scanner you are asking about but typically they do not scan at the same time. The radio tunes (very Quickly) to each Channel (or Frequency), listens for activity and moves on. This happens very fast but not simultaneously.
elijam1
For all of your Scanner Needs ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Free scanner frequencies
i recently bought a uniden bc72xlt and had no freqs. found some for my area at these sites.try www.scanner master.com*-frequency resources and home of police and call,www.radioreference.com,www.bearcat1.com,hope some of these sites help you out.
Nov 07, 2008 | Radio Shack Pro-95 Handheld Scanner
Robert
Sep 12, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-94 Scanner Logo
62 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
