Question about Pioneer HDJ-1000 Professional Headphones
My pioneer pro dj 3500 speeds up and down by itself, sometimes spins super fast other times so slow it comes to a stop! When this happens the buttons will not work. brought this new and have had it about 3 mounths.
5 Suggested Answers
  • 4 Answers
SOURCE: Pioneer sd532hd5/kuxc/ca powers down on its own
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Posted on Dec 28, 2006
C-Dog
  • 84 Answers
SOURCE: Pioneer Plamsa CMX 43"
pioneer customer service: 800-228-7221
C-Dog
Posted on Feb 10, 2008
SOURCE: problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Posted on Sep 07, 2008
  • 661 Answers
SOURCE: Pioneer DVD 717 - Not
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
Posted on May 10, 2011
Testimonial: "much appreciated. will follow advice and am crossing fingers!"
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
My washer when it goes to spin the motor sounds like starts n stops starts n stops
Check your speed selector switch (fast/slow, fast/fast, normal/fast etc.)first and foremost! Make sure it not set in-between speeds.
If it is ok then my nest bet is that the switch itself is bad.
If your machine does not have a speed selector switch, I'm afraid you may have a bad motor.
Good luck!!
Jun 15, 2010 | Kenmore 22422 Top Load Washer
2002 F250 4x2 SC - abs light comes on momentarily under hard acceleration, speedometer drops down at same time then pegs back up to normal speed. Coincides with tranny downshift. No loss of power, no wheel...
I bet you also lose the function of your cruise control when it happens. I would start first with checking the wiring connection on the vehicle speed sensor (also acts as abs sensor). Remove the sensor, clean it up and reinstall. If that doesn't work, replace the VSS.
You will find it on the top of your rear differential.
Side note: If you ever get stuck in the mud/snow and have to rock the truck forward/reverse, sometimes that will trigger your ABS light as well. This will normally reset itself after a few on/off cycles of the engine.
Dec 23, 2009 | 2001 Ford F250 Super Duty Super Cab
Will rarely eject Cd
Either switch is about to go bad, or the plastic activator underneath the eject button, which activates the switch is worn.
You can open it up to look, but I would suggest professional repair for something like this. If the electronic switch is bad, it will need to be replaced, and un-soldered from it's board.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 16, 2009 | Pioneer CDJ-800 Turntable
I didn't touch the pitch adj control, i didn't touch the reset button, i just put on a record press play then it run sometime fast and slow and fast and slow and..
This is an issue with the main drive circuits. You have what we call the 'washing machine' affect.
Only a qualified technican can repair this for you. Not too costly, if the tech knows what to look for. If not, then he will spend many wasted hours trying to find the damaged circuits. Make sure you explain the issue to them and ask if they've fixed it before.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Mar 07, 2009 | Technics SL-1210MK5 Turntable
Broken sound from cdj800 mk2
This probably has nothing to do with the CDJ unit, and more to do with your recording speed and quality. Record at either 2x or 4x - yes, I know it's slow, but you'll get a better quality recording out of it.
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Nov 28, 2008 | Pioneer CDJ-800MK2 Turntable
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Cd malfunction
Lens cleaners aren't enough. You might have to take it to a service center to have it opened up and professionally cleaned.
If there is no damage to the cd traverse assembly, then the issue might be with either the quality of your burned CDs, or method used to burn.
I always tell people to burn at slow speeds - 4x is ideal. Yes, I know it's slow, but it will burn your cds at a better quality.
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Jul 01, 2008 | Pioneer CDJ-800MK2 Turntable
Extra Spin cycle?
(I know this is an old question, but its probably a common question for new owners - including me a couple of weeks ago...)
Power the unit back on, press the spin speed button and it will select the "drain and spin" cycle. Pressing the spin speed button again will select different spin speeds as well as just "drain".
Something you might try instead of medium spin speed is to turn on "SpinSense". To turn this on (and off), press and hold the "Stain Cycle" button for 3 seconds while any wash program is in process.
What SpinSense does is measure the imbalance by doing a very slow spin before cranking the spin speed up (and measuring how constant the very low spin speed is). If the balance is out too much, it will stop, let the clothes drop, and then try another slow spin. It will try this over and over many times until the balance is decent. Then it will let it rip. It makes a huge difference, but it can spend a lot of time getting a good balance some times.
SpinSense also seems to be able to detect if the machine is shaking terribly, shut the spin down and try again.
Our LG 2688 is on our 1st floor (wooden floor). Without SpinSense, the vibration was terrible and with it, it is tolerable.
For some reason we typically get less vibration with "Extra High" spin speed compared to "High" so that is another option you might try.
May 08, 2008 | LG WM2688H Front Load Washer
Wht up dj mage asks
If you need repair for your mixer, you can always ship it to us here in NY. We offer free return shipping. We specialize in Pioneer DJ Repairs.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 13, 2007 | Pioneer DJM-600 Silver Professional DJ...
Pioneer HDJ-1000 Professional Headphones Logo
76 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
