Question about Dryers
Which direction electric dryer drum direction> clockwise or counter clockwise
  • 10,515 Answers
It's always in Clockwise direction.
Thanks for using ' Fixya ' and Have a nice day!!
Posted on Jul 19, 2009
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
The dryer made a clunk sound and the tumbler stop rotating
Sounds like you belt has either broke or came off. If you were rotating the drum by hand in the counter clockwise direction when it clunked, there is a pulley kit to fix that problem. If it was just running when it clunked the belt probably just broke. Hope that helps
Aug 29, 2011 | Samsung DV448AEE Electric Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
Jan 09, 2011 | Frigidaire Electric Dryer
I have almost the same problem... but I have plenty of heat.
If it's takeing that long and your element (coil) is that hot your exhaust is probablly blocked it will need to be cleaned out.
Oct 05, 2009 | GE DLSR483EE Electric Dryer
Older GE dryer: heats fine, drum doesn't turn
check that the blower housing is clear of foreign objects by trying to move the drum by hand in a counter clockwise direction ,dont go to far just try and move it, if that is clear, it will move freely, if not clear blower housing, if that is not your problem then you may have a bad motor.
Sep 10, 2009 | Whirlpool WED5500S Electric Dryer
Dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
MDE5500AYW Drum belt
I dont think you broke the belt, I think it may have just come off the belt tensioner. Take the bottom of the back panel off and I think you will see it hanging in there. Just put er back on.
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Belt broke on GE Dryer model #DDE7500BALWH
You will need a WE12X82P belt, or just a WE12x82 (the P stands for packaged)
  • Disconnect power
  • Remove screws under the front edge of the dryer top
  • Swing top up and remove one screw from each side panel holding the dryer front, near the top of the dryer.
  • Pull dryer front forward a bit and lift off bottom pegs. Swing to the side. (no need to disconnect wires if you don't want to)
  • Put belt around drum, lifting drum a bit to get belt past drum support slides on the bottom side.
  • Check to make sure drum slides are not worn through, especially the one on the left side.
  • The grooved side of the belt touches the drum
  • Belt runs from drum directly to motor pulley on the left side, then around belt tensioning wheel and back to the drum.
  • Turn the drum a revolution or two (counter clockwise) before reassembly.
Oct 04, 2008 | Dryers
Dryer belt replacement
Here's a URL to a website showing an exploded view of the parts in your washer, and I noticed that one of those drawings shows the proper belt path for installation: --> http://www.partselect.com/MultiModels.aspx?ModelNum=CDE6000&searchTerm=&RefineSearch=0 Hope this helps! :)
Aug 02, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
